Sparky
Front End Friday
Tonytoro416
  • Like 4
  • Excellent 4
Pullstart
A little throw back to 2019... “Frank” the 1073 Custom
  • Excellent 2
ebinmaine
@davem1111
How do you like those front sneakers?
Any chance to really test the turning traction yet?
ebinmaine
I know this one's kinda cheating a little bit but.....
  • Like 4
  • Excellent 4
  • Haha 1
davem1111
5 hours ago, ebinmaine said:
@davem1111
Oh yeah, I've had this baby all over the farm. Very happy with these.  This is my GT-1848 with the Honda engine, BTW.
Lee1977
Those should do great, I looked at them but the largest I could find were 16 x 650 x 8. chose these 19 x 7 x 8.I'm real happy with mine.
  • Like 4
  • Excellent 3
ebinmaine
Excellent.
That's what's going on Trina's 867 at some point this fall.
rjg854
2 hours ago, ebinmaine said:
Excellent.
So what you're saying is once Trina gets time   :teasing-poke:
  • Heart 1
Monstrosity
  • Excellent 9
ebinmaine
That is EXACTLY correct!!
:lol:
ineedanother
On 7/7/2023 at 7:00 PM, JCM said:
C-120  &  417-8 helping out around the property.
Hey @JCM, what's that on the front of the 417?
  • Like 5
JCM
Mount for a front tine rake @ineedanother  :thumbs:
Sparky
867 in the garage for fluids/grease…
  • Like 5
  • Excellent 2
johnnymag3
  • Like 7
  • Excellent 2
peter lena
@Tonytoro416 noting your snow blower and plow set up , did a lot of drive belt detaling on mine . especially at the pully frame , at back of blower , enhanced metal / metal frame lubricant , also re greased  pulleys on that set up , also added a stronger spring , to assist belt grip, also went after auger chain , lube , never let it dry out  , snow side cutters are oposet  correct setting . also enhanced auger drive bearings , lubricant , collectively , the unit spun up with ease at belt point , was like a sled before . also detailed in the plow , steering quadrant ,  linkage firm up , lubricate , spring slide pull on squeeze lever , lucas red aerosol grease , washer firm up start points , build mine on milk crates , verify gain and movement ease . 1/8 hair pin pring clips , at back of frame , lever hole set . have not found a related , lever / linkage , that could not be improved , chute swivel base , plastic snow slide gasket , super lube , like butter . no sarcasim , negativity , just some ideas . blade looks clean , just what you want for release . pete
AMC RULES
  • Like 4
