Similar Content
By tractorboy79
By wh315-8
I have a question about the 69’ model. I took my tank out to work on carb easier. A couple weeks later as I put it back together & after cleaning everything; I replaced the white weatherstripping that was at bottom of tank and on the corners of the strap. Seems to be all that holds it in place. Because the strap around the tank will not go around the metal bracket on bottom and fit the tank. And even if it did the strap would only line up with the bracket mounting bolts which would be in the way. What did I miss? Didn’t pay close enough attention when I took it apart and can’t see in the parts diagram where the strap does go around the bracket. The weather stripping is tacky enough that the tank stays in place and it is a made to fit perfectly in position. Just seems that the metal strap is pointless.
By tractorboy79
I have a old gt14 and the plastic plates or control panels are way past their prime, and I saw someone was remarking them with a 3d printer a little while back and I was looking to se if I could find the file but no luck. If anybody has info that would be amazing. Thanks for your time and anything helps.
By WHW
I just recently purchased a wheel horse that I was told was a 1974 raider 10 after doing research on this forum my ID tag says that it is a 1968 raider 9 but the stickers all say raider 10 The Tecumseh engine has got the b code on it which says this it makes it a raider 9 why did they put raider 10 badges on it if it's a raider 9
By Wheel Horse 3D
I recently began pondering what all i could 3d print to dress up a horse. I'm pretty good with deaign sofware and came up with a couple small items to start, and figured i can easily print things like headlight covers, hood ornaments, and badges of all sorts.Then I wondered if maybe rather than a decal if i 3d printed an embossed plate or sorts with the appropriate graphics in 3d. These could be enamel painted, or printed in a silver that would give a brushed nickel type of finish.
Here's a couple photos of what ive created thus far in some gray test material. Please let me know what ya think.
