953 nut
Wiring diagrams to help you understand how it is done.
RandyLittrell
  On 7/2/2020 at 3:58 PM, ebinmaine said:
I try as hard as I can to buy wire that is 100% copper. I don't know if there is any merit to it but I have read that the CCA or Copper Clad Aluminum can have a tendency to corrode due to the rules of dissimilar metals.
Maybe 3 years ago now? I bought a 50-foot spool of full copper 7 conductor trailer wire.
That gives me the option of cutting the outside sheath off and using seven individual wires or leaving it on where I might want it to run through something like the gas tank shelf.
I don't do restorations. We build workers. So the actual color of the wire is less important to me than it is to some.
What gauge did you get? I am thinking 14 AWG .
Randy
ebinmaine
Randy
Yes that's correct. 14 gauge is more than enough for each single circuit on these tractors.
If you're going to buy online do some research first. I had to order some red wire the other day and I found that 12 gauge was about the same price as 14 so I opted for the larger wire.
RandyLittrell
I research things to death, before I buy!! LOL
Randy
  • Haha 1
ebinmaine
Randy
If it would be helpful to you I can p.m. you a link of what I bought, later today.
RandyLittrell
Whenever would be great, no hurry. Thanks.
randy
tunahead72
Randy
You should see my 3 pages of notes on 7" replacement gauge wheels for my mower decks! :coffee:
  • Haha 2
illinibrew
Thank You!  I was going a little blind on google trying to figure this out.  Newbie to WH here.... nice place you all have created here.
ebinmaine
Welcome aboard.
Feel free to post threads and ask your own questions in existing ones.
953 nut
:text-thankyouyellow:                Lots of great folks here willing to share information. Click on this link and do an introduction so we can get to know you and your  :wh:.                https://www.wheelhorseforum.com/forum/47-introductions/?do=add
:WRS:
Edited by 953 nut
WHX??
:WRS: @illinibrew
Yes please do tell us about yerself and yer :wh:
cschannuth
This is great information!
ebinmaine
  On 6/12/2018 at 8:56 PM, 953 nut said:
  use the 5 post ignition switches  103-990 for Battery Ignition.
Battery powered ignition with solenoid, points, condenser, Starter Generator and a mechanical voltage regulator.
5b202ef98cc34_wiring-starter-generatorwithbatteryignition.jpg.24ab0ca0cab6d9b8f7d7ffb2a7a42fbc.jpg
@Retired Wrencher
Here ya go Gary.
:handgestures-thumbupright:
Retired Wrencher
  On 6/10/2024 at 8:46 AM, ebinmaine said:
@Retired Wrencher
Here ya go Gary.
Thanks Eric. I will send you some picks today. Of what I have.
Handy Don
FWIW:
- 14ga in household wiring safely handles 15 amps at 120 volts --- that’s 1,800 watts.
- 16ga handles 13 amps @120 volts -- that’s 1,560 watt.
The strongest stators on a Wheel Horse generate no more than 20 amps at 15 volts --- that’s 300 watts.
Save your money and the resources. 16 gauge is PLENTY.
  • Excellent 2
953 nut
  On 6/10/2024 at 1:19 PM, Handy Don said:
FWIW:
:text-yeahthat:
16 gauge is all you need for anything but battery cables.
Those ratings are for multiple conductors in conduit where heat is not rapidly dissipated, in open air you can go 50% over with no problem.
Rick3478
  On 6/10/2024 at 11:27 PM, 953 nut said:
:text-yeahthat:
It's also relevant to high temperature environments, like under the hood of a garden tractor with an air-cooled engine.
953 nut
The wire gauge you should use can very with the length of the wire as well as the power (Volts multiplied by electrical current) that is being used. @squonk posted a site that explains this very well.  Here is a link to this site,   https://jascoautomotive.com/automotive-wire-amperage-capacity-chart/  Thanks for posting this Mike.
ebinmaine
@Wheelhorse#1
953 nut
If you want to update the cranking system on a solid state Tecumseh or other magneto ignition engine using a solenoid and the more modern 103-991 ignition switch this is the drawing to work from.
  • Similar Content
    • Claire Smith
      By Claire Smith
      Is there a wiring diagram for a wheelhorse R26 Tecumseh engine 5.5hp - changed points and condenser, engine turns on key but no spark. !! Any ideas?? 😊
    • 70.5TransAmDan
      By 70.5TransAmDan
      Hello Everyone, my name's Dan and I'm a wrenchaholic.
      Um, sorry.
      That's Thursday nights meeting.
      First, thank you to all you old farts out there like myself and don't get me wrong. There are many young, Old Farts in this world also.
      I think of anyone that sees beauty deep inside an old tractor, samurai sword, and yes, even a lovely lady could qualify also.
      If you're the type of person that has the patients and other qualities that's needed to bring beauty and life back to something others see as old junk, or past it's prime, you're my kind of person.
      To the point now.
      I ran across a 1980ish Argo 8x8 Amphibious vehical for the right price the other day, FREE, and of course it has the infamous Starter/Generator system. Also, it's had many unqualified druggies, and electrical experts, work on it before me.  I'm retired union electrician and fiber optic engineer so I was once qualified but,. But,. But, what was I talking bout?
      You get my point.
      So, I was wondering if anyone could possibly point me in the direction of a midg,,,,,,. Wait,. Little Person, preferably a female and  blonde, so I won't have to do so much bending over working on this darn thing and while you're at it, maybe a wiring diagram for a complete starter/generator including a three wire voltage regulator?
      If you have information on either of these, the help would be most appreciated.
      Really, she doesn't even have to be blonde or little.
      That ought to show you just how willing I am to work with others.
      Thank all of you here for sharing your wisdom so it can be handed down for others to learn.
      70.5TransAmDan
    • Gingerbread
      By Gingerbread
      I’m new to this and not sure if I’m doing this right, But I have a 211-4 with a Briggs 11hp and the thing was sold in my town years ago when it was new. it was my grandfathers till now so it’s a nice piece of history. and it has some electrical problems I can’t figure out, It blows the 15Amp fuse as soon as you turn the key, it all started after the I had to replace the the ignition switch. And now it just blows the fuse. I messed with it when it happened but I have been away in the service for about two years, but now I’m on leave and want to fix my pride and joy but don’t know if my wires are all in the right spot. And my brother actually hooked the battery up backwards by accident for a few seconds while I was away so don’t know if that did anything. So any helpful suggestions or pictures for an example to look at. Thanks
    • illinibrew
      By illinibrew
      I have been into garden tractors for a few years.  Wanted to learn about small engines and buying an old sear suburban was cheaper than the class at the local community college.  Just got a 1980 C85 (with a johnny bucket on it).
