Countdown To Christmas!
mikeeyre74
Spring for parking brake and idler on Sundstrand
mikeeyre74
There is a non-original spring on my 1969 Charger that holds the engine to transmission idler puller tight. I don’t have another to compare it to. Can someone give me a part number or some dimensions or tension or some kind of guidance as to a proper replacement, maybe from Tractor Supply or something? Or is it just not that critical and I’m over thinking it?
gwest_ca
Part number 6135? It is still available from Toro
3-5/16" between hooks
coil 5/8" diameter 2-3/8" long
 34 coils of .070" wire
Garry
mikeeyre74
And don’t that beat all....
Original parts!
..an original from back in the day right on the shelf at my sorta local place. Thanks!
mikeeyre74
Where does this go?
I’m having a bit of a brain fart here, but is this how the spring is supposed to be attached?  What’s that little nut and bolt sticking out right in back of the spring supposed to do… Is that just a stop for the idler when it’s in the “up“ position? Or does something else go there?
mikeeyre74
Also, what goes in this hole? Is it just a cotter pin or something more?
What holds this?
KC9KAS
The spring looks correct.
In the 2nd photo, this is what I use:
5/16 in. x 2-3/4 in. Wire Round Lock Pin (5-Pack)
gwest_ca
Hairpin cotter in a manual - no mention of size
Garry
gwest_ca
If you have a newer tractor with the pto hoop this same pin is used at the bottom of the hoop where it pivots at the tractor frame.
mikeeyre74
Thanks fellows! I couldn’t manage to find that info by myself. Thanks for the assist. I’ll get the right piece tomorrow.
