mikeeyre74 289 #1 Posted June 5, 2018 There is a non-original spring on my 1969 Charger that holds the engine to transmission idler puller tight. I don’t have another to compare it to. Can someone give me a part number or some dimensions or tension or some kind of guidance as to a proper replacement, maybe from Tractor Supply or something? Or is it just not that critical and I’m over thinking it? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,101 #2 Posted June 5, 2018 Part number 6135? It is still available from Toro 3-5/16" between hooks coil 5/8" diameter 2-3/8" long 34 coils of .070" wire Garry 1 Share this post Link to post Share on other sites
mikeeyre74 289 #3 Posted June 12, 2018 And don’t that beat all.... ..an original from back in the day right on the shelf at my sorta local place. Thanks! Share this post Link to post Share on other sites
mikeeyre74 289 #4 Posted June 15, 2018 I’m having a bit of a brain fart here, but is this how the spring is supposed to be attached? What’s that little nut and bolt sticking out right in back of the spring supposed to do… Is that just a stop for the idler when it’s in the “up“ position? Or does something else go there? Share this post Link to post Share on other sites
mikeeyre74 289 #5 Posted June 15, 2018 Also, what goes in this hole? Is it just a cotter pin or something more? Share this post Link to post Share on other sites
KC9KAS 4,741 #6 Posted June 15, 2018 The spring looks correct. In the 2nd photo, this is what I use: Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,101 #7 Posted June 15, 2018 Hairpin cotter in a manual - no mention of size Garry Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,101 #8 Posted June 16, 2018 If you have a newer tractor with the pto hoop this same pin is used at the bottom of the hoop where it pivots at the tractor frame. Share this post Link to post Share on other sites
mikeeyre74 289 #9 Posted June 16, 2018 Thanks fellows! I couldn’t manage to find that info by myself. Thanks for the assist. I’ll get the right piece tomorrow. Share this post Link to post Share on other sites
