Butch
Now that tractor supply no longer carries their Valspar Implement paint what spray cans are people using on their wheels?
Thanks!
Butch
S. Jersey
Achto
Many members have used Rusoleum spray paint on their tractors.
KC9KAS
Depending on the tractor, but I use RUSTOLIUM ALMOND.
oliver2-44
For rims I use Rustoleum Appliance Epoxy in the Linen color
Butch
Thanks guys! Rustoleum it is!!
giddyap
For what it's worth. This new nozzle shoots a straight line spray like a professional sprayer. BIG IMPROVEMENT
"D"- Man
Can this be removed and press fit on to a Rust-Oleum spray can?
giddyap
Rust-Oleum can on the left is different. I'm not ready to experiment, with my luck something will break and I'll lose a can of paint. But I did discover the nozzle rotates for up/ down pattern or side/side pattern.
c-series don
I don't think that they are interchangeable. Rustoleum needs to come up with a better nozzle!
giddyap
I did use Krylon "Banner Red" from Walmart. It has the same can as Rust-oleum. While shopping at ACE I discovered they had my color. That's how I discovered Ace's superior nozzle. So the question is, whose paint is Ace using? Whatever brand name and color you are now using, You just might find the same color in the Ace can with their superior nozzle.
Edited by giddyap
MAH
http://www.agspecialty.com/indstrial.htm
This is what I use. Works good, lays nice. I haven't sprayed any body panels but the wheels came out good from a rattle can. The chassis stuff I've uses both rattle cans and sprayed with a top feed. All my colors are spot on even with different cans.
One of my local mom and pop shops in the area carry it.
Edited by MAH
