Countdown To Christmas!
moe1965
14hp kohler. Spark plug proper plug
moe1965
I have a 14hp kohler k321AS engine the champion plug it's calling for is a rc12yc plug.  Unless I'm reading the wrong info. It has a j8c in it now .  The plugs are noticeably different.    Which plug is correct?   This wheel horse is new to me so I don't know if the P.o. had the wrong plug in it.  Thanks in advance
KC9KAS
Check this out @moe1965
KOHLER_SPARK_PLUG_CHART.xlsx
Something went wrong!
Edited by KC9KAS
953 nut
Champion H-10C gaped at .035 if you have a points ignition system. The J-8 is for a K-90 and the RC-12YC is for a Kohler twin.
moe1965
Thanks.  I have a k241s as well that has a j8c in it as well.  Is this the wrong plug as well???
Edited by moe1965
pfrederi
K241 also uses H10C...unless you prefer something that works under compression in which case autolite 216...(Sorry i wasted a lot of time a few years ago with a champion plug that would not  fire under compression...fool me once shame on you,... twice shame on me.
  • Haha 1
953 nut
Sorry Paul, I got all the good ones!     :ychain:
  • Similar Content
    • Stuart
      By Stuart
      I am giviing my Wheel Horse some long over due attention. It was stored after developing some spectacular somewhat frightening backfires. I have purchased a new carb and removed the head to clean away the heavy carbon deposites. Ground the valves and reset the the valve clearances. Prior to adding fuel , I performed a compression test which resulted in virtually no compression whatsoever, upon removing the head and inspecting the valves , I am mystified to why the exhaust valves opens a little on the compresion stroke ? Increasing the valve clearance to 0.050" prevents this occuring, raises the compression to 50 PSI, but the starter motor finds this dificult to cope (still not add fuel yet). I cannot work out why the cam should wear in this way ? So there must be another explanation but other than some sort of decompresion reason I can not think of one. Any guidence on this subject will be much appreciated, I am based in the UK and I am sure there are other owners of such machines but I do not know of any. ps. I am purchasing parts from the USA.
