PBugz 0 #1 Posted June 1, 2018 I have a 12 horse 8 speed I would like to put hyd. lift. I have the cylinder valve & hoses for a Wheel Horse. I need the pump & tank. Dose anyone know where I can get them? Share this post Link to post Share on other sites
pfrederi 17,666 #2 Posted June 1, 2018 Short answer is you can't do it.. The wheel horses that used the hoses, cylinder, and valve that you have were all hydros. The hydro drive provided the pressurized fluid. 8 speeds had an optional electric lift Welcome to Red Square Longer answer if you are a good fabricator you could rig up a PTO driven hydro pump.... 1 Share this post Link to post Share on other sites
953 nut 55,077 #3 Posted June 1, 2018 I have seen an automobile power steering pump and reservoir used to power a hydraulic lift on a garden tractor, wish I had taken a picture of it. 1 Share this post Link to post Share on other sites
JPWH 6,033 #4 Posted June 1, 2018 You can buy a belt driven pump at northern tool. Like mentioned above, with a little fabrication you could have a tank. The fittings and hoses can be custom made. Share this post Link to post Share on other sites
KC9KAS 4,741 #5 Posted June 2, 2018 @PBugz to Good luck with your project, and we love photos! 1 Share this post Link to post Share on other sites
