mikeeyre74 289 #1 Posted May 31, 2018 Does anyone know offhand the torque spec for the 10 Pinion limited slip differential bolts? Share this post Link to post Share on other sites
Racinbob 10,869 #2 Posted May 31, 2018 20 ft. lbs. 1 Share this post Link to post Share on other sites
mikeeyre74 289 #3 Posted May 31, 2018 That’s it? Weak! Share this post Link to post Share on other sites
stevasaurus 22,529 #4 Posted May 31, 2018 you want to use the nylon nuts. That's why it is not a lot. Actually, I think 20 ft lbs is what the torque is for lug nuts on your car tires. 1 Share this post Link to post Share on other sites
953 nut 54,382 #5 Posted May 31, 2018 7 minutes ago, stevasaurus said: you want to use the nylon nuts. 8 minutes ago, stevasaurus said: I think 20 ft lbs is what the torque is for lug nuts on your car tires. You may want to rethink that one big guy! CONTOUR - SVT ALL / SVT 1998 - 1998 85 ft-lbs CONTOUR ALL / P185/70R14 1998 - 2000 95 ft-lbs CROWN VIC 2/4 DOOR / P205/75R15 1987 - 2011 100 ft-lbs E-150 15"OPT. / STEEL WHL. 1992 - 2006 100 ft-lbs E-150 VAN / ALL 2007 - 2014 140 ft-lbs 1 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,237 #6 Posted May 31, 2018 53 minutes ago, stevasaurus said: you want to use the nylon nuts. That's why it is not a lot. Actually, I think 20 ft lbs is what the torque is for lug nuts on your car tires. @stevasaurus That is the torque specs for the bolts that hold the Squonk 's head on his neck. 1 4 Share this post Link to post Share on other sites
WHX?? 48,067 #7 Posted May 31, 2018 14 minutes ago, elcamino/wheelhorse said: torque specs for the bolts that hold the Squonk 's head on his neck 1 Share this post Link to post Share on other sites
WHX?? 48,067 #8 Posted May 31, 2018 1 hour ago, mikeeyre74 said: That’s it? Weak Some of the side plates are aluminum and over torque WILL crack them. 3 Share this post Link to post Share on other sites
stevasaurus 22,529 #9 Posted June 1, 2018 I stand corrected gentlemen. Sorry for giving wrong information. Not sure what I was thinking. 1 Share this post Link to post Share on other sites
squonk 40,740 #10 Posted June 1, 2018 On 5/31/2018 at 5:39 PM, elcamino/wheelhorse said: @stevasaurus That is the torque specs for the bolts that hold the Squonk 's head on his neck. What? You think I wouldn't see this didn't ya. You old guys need to find something to do during the day. Here's something to keep you busy: What is the proper tool to tighten them. Torx? Allen Wrench? Hex ? ECT ECT. See if you can figure it out! Share this post Link to post Share on other sites
953 nut 54,382 #11 Posted June 1, 2018 42 minutes ago, squonk said: What? You think I wouldn't see this didn't ya. You old guys need to find something to do during the day. Here's something to keep you busy: What is the proper tool to tighten them. Torx? Allen Wrench? Hex ? ECT ECT. See if you can figure it out! Any questions? 4 Share this post Link to post Share on other sites
squonk 40,740 #12 Posted June 1, 2018 I don't see the proper tool or tools! Please try again! 1 Share this post Link to post Share on other sites
squonk 40,740 #13 Posted June 2, 2018 I'll give the answer after 3 tomorrow 1 Share this post Link to post Share on other sites
DennisThornton 4,769 #14 Posted June 2, 2018 Good lord! You guys! 🤣 1 2 Share this post Link to post Share on other sites
stevasaurus 22,529 #15 Posted June 2, 2018 If it is the bolt between the head and the neck...it is a head bolt and requires the biggest torque wrench in the tool box. The one with foot pounds. 1 2 Share this post Link to post Share on other sites
squonk 40,740 #16 Posted June 2, 2018 47 minutes ago, stevasaurus said: If it is the bolt between the head and the neck...it is a head bolt and requires the biggest torque wrench in the tool box. The one with foot pounds. Close 1 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,237 #17 Posted June 2, 2018 @stevasaurus Don't over torque the nuts , may bust the aluminum side plates that holds Skonky's ears. 2 Share this post Link to post Share on other sites
squonk 40,740 #18 Posted June 2, 2018 Ok the Big Reveal! Ol' Case de ElCamino is going to have to find his tool box to see if he has the "Proper Tool(s) to torque my "head bolts" And here they are: You will need the tamper proof bit on the left and this left handed Metric torque wrench! No substitutes allowed as they will void all warranties! 1 3 Share this post Link to post Share on other sites
stevasaurus 22,529 #19 Posted June 3, 2018 Well...isn't that special. 1 1 Share this post Link to post Share on other sites
