702 timmy
k-341 for a k-321
702 timmy
looking at upgrading my c-100 10 horse to a 16 horse. Can a k-341 fit into a c-100 space?  Any complications? Thanks  timmy
wallfish
It'll fit.
The only thing may be the spec of the replacement engine. Wheel Horse spec Kohler engines have threaded holes in the bottom of the oil pan for mounting bolts to go through the frame and into those threaded holes. You should see these threaded holes in your 10hp oil pan
702 timmy
I think the k341 is from a wh Richmondred has it. Thanks for the answer, has anyone done this before?
thanks tim
oldredrider
I do it all the time. Like Wallfish said, if it's a Wheel Horse spec engine,  it'll work.  BTW, your 10hp pan will bolt right up to the 16 if you need that style pan.
Plug and play.
Racinbob
:text-yeahthat: As long as the K-341 isn't off a shaker mount. For all practical purposes a 10, 12, 14 and 16hp models are the same size on the exterior. I put a 16 on a 76 B-80 and it was bolt in but in 76 and 77 the B's were the same frame, tranny, etc. as the C's.
squonk
Aint nothin like a Thumper! :banana-wrench::banana-wrench::banana-wrench:
  • Haha 2
Warning:Unsupervised
 Oh' the wheels in my noggin go round & round, all daaay long, Humm Humm.
  Sorry if you sing that later, if not well I tied...lol
  Been thinking over winter I may put a 14hp on my old smokey 310-8 Wheel Horse? Didn't know a 16hp was same dimension?
I know this post is real old but if anyone reads it again I have a few questions. Its curiosity at this point, only asking because last yr when I looked at rebuilt short blocks, K series were both cheaper & easier to locate. Surely best to keep a Mag on Mag & K on K Tractor but fwiw just how much hassle is it to swap?
Q1) Mag to K-Series?
 Can one put a 14hp Mag engine on K10 Tractor very easily?
Q2) Ignitions?
   Tractors with 10hp Mag have (elect ignition) vs K-Series Points? What changes are needed?
Q3) Charging?
I assume the oem starter & charging system simply remains same?
 Any changes necessary here?
Thanks all....
Gasaholic
Yes, fairly easy. can go either way (complete K series in place of Magnum, and vice versa) Only real differences to think on: Rewiring (You'll need to swap out ignition switch, best to understand wiring circuits and how to test each circuit so you can verify you got things wired right before hooking in battery!)  and engine mounting (Oil pans mainly - but oil pans can be swapped out between the 2 blocks however - Magnum block is basically a K series with magneto coil mounting standoffs added and breaker plunger hole plugged off - You can use a magnum block to rebuild a K series, but not the other way around.)
  10 hours ago, 123GO said:
Q2) Ignitions?
Pretty much new switch and some wiring changes, as noted above.
Q3) Charging?
Thanks all....
charging systems and starters are pretty much interchangeable between Magnum and K series.
Depending on your skill set & know-how for reading wiring diagrams, you can swap out a Magnum engine for a K series fairly easily (For the K series short block , you'd need points, condenser, coil, breaker plunger, breaker box cover & related hardware to replace the magneto ignition of a Magnum)  which means you would need to re-wire switch & electrical harness to suit the changeover.
However, a K series short block won't work to rebuild a magnum, as noted the K series will not have the magneto coil standoffs (cast into the cooling fins area) so there'd be no way to mount a magneto coil to the engine.   However, a Magnum short block can possibly be used to rebuild a K series (Depending on how old the short block is, older blocks still had the breaker plunger hole & screw threads for breaker points & cover, they were just plugged off with expansion plugs) - It'd just need the holes for breaker plunger, breaker set & breaker cover drilled & tapped.. Otherwise the blocks as a whole are pretty much identical between K series & Magnum.
kpinnc
Actually the blocks and internals are the same. The aluminum bearing plate on the flywheel side is how they differ. You can swap them (be sure to reset the crank end play with the paper shims), and remove the points pin plug for Magnum.
Gasaholic
Right - As I said, POSSIBLY.   Early magnums used the K series block and still had the mounting and holes drilled for the breaker points. However, later magnums did not have the plunger hole or breaker mounting screw holes drilled and tapped, so you could not use those blocks to build a K series (no place to put the points).  As to going the other way you'd be right, you can use a 10-16 horse K series block to build a Magnum - I was wrong on that point, I think.
(Foggy memory - I seemed to recall they had spots cast into the cooling fins for mounting magneto coil, but that may have been a different engine brand..? I've been retired from the business a long time, so I couldn't recall why we couldn't use a K series block on a Magnum, I just seem to remember not being able to do that a couple times, but maybe it was the 8 horse Magnum? Just know there was some stumbling block on a couple particular rebuilds we did, but this was back in early 1990's.  Or maybe it was just the aforementioned points mounting issue.)
squonk
Not all charging systems are the same. Some have the 2 wire stator. some have the puny 3 amp single wire
  Great, exactly the info I needed, glad I'm not so limited. Haven't looked very hard for a Mag, only for a minute actually but I just noticed each time only reman K's were available.  It just made me wonder if I could swap it to one if necessary?  I never even considered doing a Mag/K swap?
Big thanks, I can handle this one easy & appreciate your knowledge & your time here folks.
Edited by 123GO
  • Similar Content
    • Bill D
      By Bill D
      I have a GT1800 that I have swapped an M14 into.  The original drive belt is too long for the Kohler.  I tried a 7473 belt and that was too long.  I'm guessing I need an 81" belt.  Does anyone know for sure?  I'm thinking it should be the same length as a 314H?   I'm trying to avoid multiple trips to TSC with the price of gas.  Yes, I do have the correct hydro pulley on the Kohler.  Thanks.
    • RedPaul
      By RedPaul
      I need some wiring help.  I am swapping a Kohler CV16S from a Scotts (JD) in to a Crapsman YT 3000 that formerly had  A Briggs engine. PO of Crapsman forgot the part about checking oil regularly. PO of Scotts changed engine oil but didn't own a grease gun thuse entire front steering gear trashed.
      Before you start throwing things at the screen, the resulting franken tractor (Scottsman CraftDeere?) is being donated for use in maintenance of a city park in the Mexican Town area of Detroit.
      The company I work for donates time, people, and a storage area for park maintenance tools and equipment. Owner is Hispanic and doe gobs of stuff for the community both personally and through our company.
      On to the question.
      I need to marry up the Kohler engine wiring with the Craftsman chassis wiring.
      The Craftsman chassis has the following wires coming to the molex connector that used to connect to the Briggs engine.
      Chassis Blue - Connected to Grey from the  Briggs
      Chassis Blue jumperd to second hole connector - Connected to Red From the Briggs
      Chassis Black and Black with white stripe - both to same connector hole - Connected to Black from the Briggs
      Chassis Orange - Connected to Orange from the briggs
      Chassis White - this wire did not connect to anything on the briggs
      Kohler engine has the following wires coming from the engine going to Molex connector
      2 Red - both go to same connection point
      Yellow
      Black
      White
      Can anyone tell me which Kohler engine wire goes to which Craftsman Chassis wire?
      Free Scotts Chassis with hydro (it would be a roller if the front axles weren't trashed) to whom ever can sort this out.
      Thanks,
      Paul
    • The_turbo_tuba
      By The_turbo_tuba
      I have a wheel horse 516-h and I am looking to swap in a kohler single cylinder model like a k-341 or k321. Or a magnum series single cylinder. Does anyone have any idea what the swap will entail, what parts will carry over and what things I should look for on the kohler. Also I believe the mounting plate on the current set up can be removed to fit a kohler perfectly like they would be set up on like a 310-8. In new to wheel horse so I appreciate anyone's help! Thanks!
    • wheelhorsejoe
      By wheelhorsejoe
      Hi Members, I am doing an engine swap in  a 1988 W/H 520H replaced Onan 20hp with a B&S 18 hp twin opposed I/C. My problem is connecting the OEM main engine harness to the B/S, the B/S has a kill wire and the alternator wire go the the regulator. My problem is I don't know what wire is what in the harness and I'm unable to find a wiring schematic does anyone know the break down of the wire harness.. Any help is appreciated..     Thanks Joe
    • mikekot3
      By mikekot3
      Hello
      I want to buy the seat mentioned in Martin Howard's 416 adventures. I tried to contact him but he is not able to receive emails through red square.
      I have a 1993 WH 416-8 tractor. He used a KM UNIPRO 123 seat from www.turfseats.com
       Which seat switch do I use on the replacement seat? My used my FLUKE 88 dvom in auto ranging mode to test the original seat switch. With the
      seat switch disconnected I get a ohm reading and O.L when I sit on the seat. I am thinking that tells me
      that the seat is Normally OPEN.  Am I correct in this? Did the KM seat switch come with a pigtail for wire it up?
      If not how do I install the switch? Where did you get the seat rubber bumpers for the swing up seat base? I believe they were black or grey.
      Also I installed a Briggs and Stratton Vanguard v-twin 23 hp engine swap kit from small engine warehouse.
      The hour meter does not work any more after replacing the swapped in engine. I was thinking that a aftermarket hour meter/tach from esitest.com would
      work. http://esitest.com/329.html
      My other question is that I can only start the tractor by turning the key and also turning the light switch ON to engage
      the starter motor.  I am thinking one of the power wires in the white AMP engine harness connector is in the wrong pin position as I had to
      replace the connector.
      Please advise,
      Michael Kotarba
      mkotarba@hotmail.com
