Countdown To Christmas!
Horse Play
RJ58 Brake Return Spring Anchor
Horse Play
My RJ58 is missing the anchor for the brake return spring.  I want to make one, but haven't a clue what is looks like.  Can someone post photos and some dimensions for me?  Also, can anyone recommend a source for a replacement spring?
Thanks for any help!
stevasaurus
Here is a picture of it just below the axle.  It is 1/2" wide, 1" long and 1/4" stock and is flat..  The bolts that hold the side plates on are 1/2"...the bolt that holds on this piece is 3/4".  It has a 1/4" hole for the end of the spring.  They are easy to make.  :occasion-xmas:
  • Like 5
roadapples
Tractor Supply has a good selection of springs
Horse Play
Thank you very much, Steve.  Seems like a simple enough part.
Thanks, roadapples - I'll check out TSC.
Horse Play
OK, next stupid question: one end of the spring attaches to the anchor - where does the other end attach?
953 nut
The brake linkage.
Horse Play
2 minutes ago, 953 nut said:
The brake linkage.
Right, but I do not see a hole anywhere to retain the spring end.
953 nut
I don't have an assembled RJ any more, but if I remember right there was a trunnion on the end of the linkage and the spring went through the eye of the cotter key that held it in place on the cross bar to the clutch.
Horse Play
Ah, OK - makes sense.  Thank you!
Edited by Horse Play
