StanC160 5 #1 Posted May 26, 2018 What type of oil goes in the sunstrand hydros my c160 looks like transmission oil and my c161 looks like engine oil under its seat of c161 it states use 10w 30 weight why the difference and which is better plan on changing tranny oil stay with same or is one better Thanks Share this post Link to post Share on other sites
953 nut 55,835 #2 Posted May 26, 2018 You should replace the transmission fluid with the same type as it has in it presently. If it is amber colored them use 10 W 30 and if it is pink then use Dextron ATF, they are not compatible, do not mix them. The replacement filter should be a NAPA 1410 1 Share this post Link to post Share on other sites
squonk 41,360 #3 Posted May 26, 2018 (edited) For engine oil hydro's Mobil 1 For trans oil models I think it was type A which was replaced by Dexron. Edited May 26, 2018 by squonk Share this post Link to post Share on other sites
BOB ELLISON 2,981 #4 Posted May 27, 2018 Wheel horse used both transmission oil and motor oil. I have a 74 C160 that has motor oil and I use mobile 1 10w30. In my 77 C160 it has transmission oil. Share this post Link to post Share on other sites
redone 45 #5 Posted June 16, 2018 I change my trans oil with synethic aro shell. Change filter as well. Share this post Link to post Share on other sites
