SylvanLakeWH 25,472 #1 Posted May 26, 2018 Helping out a local Shrine with some new property they just picked up. It needed a bit of weed "whipping"... C-105 did the job with no complaints. Amazing power... 8 3 Share this post Link to post Share on other sites
johnnymag3 2,514 #2 Posted May 26, 2018 A wheel horse .......OF COURSE !! nice wowrk 2 Share this post Link to post Share on other sites
Sarge 3,463 #3 Posted May 27, 2018 I've often wondered - those commercial-sized walk behind wheeled weed wackers.... Why couldn't a guy use one of those heads/frame and mount it on a carrier off of the front mule drive mount and use the pto from the engine to drive it for knocking down such problem areas? Wouldn't be any more dangerous than the front mounted sickle mower, plus a lot less prone to damage/breakage. Sarge 2 Share this post Link to post Share on other sites
SylvanLakeWH 25,472 #4 Posted May 27, 2018 20 minutes ago, Sarge said: I've often wondered - those commercial-sized walk behind wheeled weed wackers.... Why couldn't a guy use one of those heads/frame and mount it on a carrier off of the front mule drive mount and use the pto from the engine to drive it for knocking down such problem areas? Wouldn't be any more dangerous than the front mounted sickle mower, plus a lot less prone to damage/breakage. Sarge Cool idea! For me the answer is easy - I don't have one and I have never maintained property other than keeping it all managed and mowed with a standard deck finish mower, so I don't really need one. I just took my time in first gear and took 50% bites at a time with two passes over-lapping. First pass in reverse (seemed to cut the tall stuff better backwards) then forward in second gear and it looked great! 1 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,497 #5 Posted May 27, 2018 Some heavy high grass to get through and a nice job doing it. Glenn 2 Share this post Link to post Share on other sites
elliot ness 1,916 #6 Posted May 27, 2018 Great tractor you got there. 1 Share this post Link to post Share on other sites
Chris T 355 #7 Posted May 28, 2018 Nice looking black hood!! 2 Share this post Link to post Share on other sites
ohiofarmer 3,265 #8 Posted May 29, 2018 (edited) I found that if you Mow crossways to the first cut it seems to cut the stragglers better. In extreme cases I get out a powerful leaf blower. to clear the cuttings so they dont lay so thick on the lawn. It can be tough on belts, however Edited May 29, 2018 by ohiofarmer 1 Share this post Link to post Share on other sites
