Builderchris
C100? Need help in identifying my new purchase.
Builderchris
I need some help. I just purchased 3 garden tractors, plus implements, from a guy on Craigslist and I'm having difficulty identifying one of them. It looks to me like it's a C100, but honestly for all I know it could be a Raider10 or a charger10 just as easily. I'm really not sure. The tag under the dashboard reads, Model T10, Serial # 329650. When I googled Wheel Horse T10 I got nothing. Can one of you great Wheel Horse guru's help me out?
Thanks
Chris
gwest_ca
Welcome to the forum
329650 looks like a 1967 serial number.
What transmission does it have?
3 forward speeds model 1057
6 forward speeds model 1067
hydro model 1077
Will guess the T10 is missing the last 2 digits and the T is not used.
Garry
953 nut
:WRS:
A couple of pictures could be helpful.   For that matter we would kind of like to see the others too.        :wwp:
Builderchris
rmaynard
Can we get a little focus on the tag?
At least we know it's a hydro.
1967 or earlier with no foot boards.
wrong hood for '67
Builderchris
Thanks for your input Bob. I can't get a clearer picture of the tag. The T10 and the serial # is all that is showing. If I look real hard I imagine that I'm seeing a "21" after the "T10" , Ibut I know that's not possible after checking possible Wheel Horse models. I think for now I'm going to go with your suggestion of it being a 1967 model year which would make it a 1077.  I discovered it had the wrong hood when I sat the hood on the machine and discovered it was approx.  2" too short. Either the hood was too short or I was losing my marbles. The hood mounting dowel wasn't right either.
Here's another question. I notice that there aren't any bolt holes on the side of the engine cover to cover the starter belt and pulley. could that be a clue as to what model or year this beast is?
Have any of you guys tried cutting off the ends of the tie rods, then drilling and tapping the rods to install a couple of tie rod ends instead of replacing the whole tie rods. I'm trying not to spend too much on this machine while my other horses are crying for attention.  I've got seven horses and one John Deere in varying states of disrepair. It's just that these things don't roll very well with the front wheels going in different directions. My son has been threatening to hold an intervention for my "Garden Tractor Addiction".
ebinmaine
See the link below. Great help for the tie rod question.
That's ok. Horses are patient.
  I've got seven horses and one John Deere :think:
.... Well.... We can work on that...
 It's just that these things don't roll very well with the front wheels going in different directions. :ROTF:
NO OOOOOHHHHHHHH !!!!!!
You tell him you're in a 12 step program and you only have 7 !!!!
http://post.spmailtechn.com/f/a/wXQs8tAsqNYrEoxSvk4ogw~~/AACuvwA~/RgRclJ3TP0RuaHR0cDovL3d3dy53aGVlbGhvcnNlZm9ydW0uY29tL3RvcGljLzc0NDA4LXRpZS1yb2QtdXBncmFkZS10cmFucy1wdWxsZXktcHJvYmxlbS8_ZG89ZmluZENvbW1lbnQmY29tbWVudD03MTU1NTNXA3NwY1gEAAAAAEIKAAbTGLJa0VDRsVITZWJpbm1haW5lQGdtYWlsLmNvbQ~~
Builderchris
The tall exhaust stack is for when you're driving through the deep snow? Come on Eric even though you're up nauth we know you're still a flat lander. Them is mighty big front tires you got there on that B80. It sounds more like a 4 x 4.
Chris
ebinmaine
Chris
:ROTF:
The stack is MOSTLY because I like the look of it.
But it is also for keeping fumes outta my face.
I wish it was taller. (More chrome too)
No flat landers here. We literally live in the first south face of the white mountains.
Them front monsters are to give me a little more clearance and floatability (that's a word right?) going through the rough forest.
  • Similar Content
    • LengerichKA88
      By LengerichKA88
      We have a Charger 10 that I’ve had on here and gotten help with, but I’d never really looked at the ID Tag.
      Today while looking around it I took note of the model number, so as to help with narrowing down parts in the future. The model number listed on the tag is 1-7931.
      After a google search, “1-7931” returns as a Charger 9. Would this be a case of using left over tags, or possibly an error?  The tractor has an HH100, and is badged as a Charger 10, but from the Charger 9 manual I found, I couldn’t find an engine model number listed, just “9hp”.
      Picture of the tag is included.
    • LengerichKA88
      By LengerichKA88
      I liked, but didn’t find an applicable thread, so I made a new post.
      We got a 69 Charger 10 last Friday. The brakes don’t really stop it, kinda slows it to an idle speed. Still too fast for the brakes to be engaged. FIL did some reading and it’s apparently the gears that stop the tractor, so now we’re looking at servicing and possible actually doing work on the trans. That’s fine, not a problem, figured we’d get into this eventually, so with the one known issue at hand, how would/have you gone about tackling this trans?
      Trying to get voices of experience that might be able to save us a headache or two lol. TIA!
    • stonecottage227
      By stonecottage227
      Just purchased a C100.  Everything was working fine for 1 day.  Got stuck in mud and pushed it out while running,  Shut tractor off and went to restart.
      Now it just makes a noise from the starter. No Clicking,  Battery is strong.  Lights work when key is engaged. Turned the drive belt by hand - turns freely.
      Tried to jump start with no luck.  I am a novice and was looking for advice.  Thank you in advance.
    • Bowdoinham Dan
      By Bowdoinham Dan
      I've got a Raider 10 that won't start and am not sure what to do, but I suspect that something needs replacing.
      ENGINE MODEL: KOHLER K241S 10HP
      WHAT HAPPENS:  I turn the ignition and hear a loud buzz/crackling sound coming from somewhere in the vicinity of the starter/battery area (PICTURED).  I turn the ignition over again and the sound repeats.  I turn it over a third time and it's dead.
      RECENT MAINTENANCE:  Replaced/patched some wiring, new battery (charged yesterday, had been sitting for the winter), new spark plugs.  I'm an idiot with the internal combustion and am probably in over my head with this thing, but willing to give it my best go with good guidance.  Would really love to get the tiller running for the spring.
      Thanks gang
      Dan
    • 69-Raider-10
      By 69-Raider-10
      Happy Easter fellow Horse Junkies! I am not happy with my Raider 10 after I swapped out the Lauson for a K181. Its not so much the difference in power between the 10hp and the 8hp, its the fact that my other 2 tractors are a Bronco 14 and a 416 8 Onan. I hop on the Raider and even though its the most mechanically sound and aesthetically pleasing tractor, it has the least cajones. I have a low hour 14hp Magnum sitting around that I was saving as a backup but I think I want to drop it in the Raider. Anyone make this type of swap before? Anything that makes it not doable or ill advisable? As always I appreciate the input and your time in answering. Happy Easter!
