Countdown To Christmas!
Ripmf666
Wheel horse C-175 from grandfather.
Digger 66
Welcome to the forum .
Looks like your grandfather looked after his stuff very well .
You came to the right place
KC9KAS
@Ripmf666 :text-welcomeconfetti: to :rs:
Nice looking machine!
rjg854
:text-welcomeconfetti: 2:rs:This is the world of Wheel Horse, any answers to your questions can be found here!
SylvanLakeWH
NICE Tractor!
Love the Black Hoods! :ph34r:
wfrpalm
Very nice tractor.
AMC RULES
:handgestures-thumbsup: Very nice tractor.
One of my favorite :wh: workers, right there.
Seems you're doing your Grandfather proud.
:WRS:
Pollack Pete
Maintain that tractor and you'll be passing it on to your Grandson some day.VERY nice C-175.Hope you think of Grandpa every time you use it.
953 nut
:WRS:
:text-coolphotos:    Your Grandfather took very good care of his :wh:, glad to see another generation is keeping it in the family!        :woohoo:
You may already have the manual, but if not this link will let you download it.
  • Excellent 1
classiccat
I'm so sorry for your loss.
Your grandfather had great taste in tractors... as well as preventative maintenance schedules!
gorgeous machine!
  • Excellent 1
peter lena
what a terrific opportunity, good for you ! I hope you retain that look and care , truly a time warp. keep it clean, serviced, pete
JERSEYHAWG /  Glenn
:text-welcomeconfetti:.     :wh:
Thats a beauty, best of luck.
Glenn
WHX??
Awesome dude! You gonna fit right in with those :text-coolphotos:
:WRS:
Edited by WHX19
Tractor boy
Welcome
Retired Wrencher
Ripmf666 :WRS:  Nice tractor. Glade you are keeping it in the family. Looks like it should be a great tractor when done.
Edited by Retierd Wrencher
Herder
:text-welcomeconfetti:  Beautiful Wheel Horse.  Your grandfather must have been very meticulous.
Al C.
What a machine!  Maintain it and continue the legacy.  It will last longer than most of us.  That's what many of these machines are all about.
  • Excellent 1
Ripmf666
I’m 41 and it’s 35 so it should live along happy life. I started driving this at 6 my daughter asked my wife when I started and if she could she’s 10.
I hade not been on much with going back to work. A newborn keeps you busy in life. I got this out of my moms house we’re its been for the last year of the 2 years since he passed. We’re cleaning out my moms house to sell since she passed away June 19th last year.
Got new belts for drive axle, deck drive and deck belt along with new blades and a oil change to do.
Wish you could find the oem seats with the horse on it. I’m tempted to put a General replacement on to keep this from getting worse.
Also want to do axle seals on rear.
Edited by Ripmf666
bumpsteer
Holly Cow nice one. I love that black hood and front.
WHX??
Good idea... many of us do that.
Blackhood Bill
Sorry for your loss nice machine there now you need to go get the others
  • Similar Content
    • Jayzauto
      By Jayzauto
      I have a WheelHorse C-175-8 with Rototiller attachment. Machine is in great mechanical shape, just needs paint.  Engine has been replaced with an identical Kohler KT-17 Series 1.  New Carb has been installed.  Battery, solenoid and cables have been replaced, starts great.  Installed new Tires and Tie Rods.  Installed radial bearings in spindles, so it steers beautifully.  Fuel line has been changed, as well as headlights.  Bew mule drive and belt fot tiller and functions as designed.  I'm sure there is other items that have been done.  Very reliable machine. $800/BRO
      Selling all my WheelHorse items and moving South.  Have other tractors ad parts if interested.
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
    • Foxer14
      By Foxer14
      My grandfather is selling his C-175 and I want to buy it from him to restore it. He thinks he can get about $3000, but I think that is too high. It does come with a mower deck that is probably to rusty to use and a tiller. He says the tractor has lots of accessories on it. It will need some work as it hasn't ran in probably 15-20 years. I was thinking about $1000 but I am not sure. What do you think?
    • Josh Opitz
      By Josh Opitz
      I have redone most electrical components and fuel of this kohler K341. new spark plug, coil, starter, battery, rectifier, Carb, rewired, but i have not done points. it starts up great idols fine. when I turn the throttle up it rises up to a certain RPM then starts to seize and puff black smoke and the throttle on the the carburetor jumps. Someone had told me it is backfiring and said i need to adjust the my air to fuel ratio. started messing with the governing arm and spring and thought it was helping but hasn't fixed it. any suggestions?
    • CB520HC
      By CB520HC
      hello all I figured its time to show off the horses that I own and tell a little about my Frankenhorse. My first one was the C-175 auto with original series 1 kt17 bought it for $100 "running" , driving and mowing. Little did I know that it had a broken connecting rod on the front cylinder I found this out due to going over it and checking plugs found the front plug soaked in fuel, and when I removed the piston from the jug the crank had a narly nick in it that I could see. So after crawling all over this forum I found out that my best option was to go with wither a series 2 or swap to the classic k341. Later that week I found a guy not too far away from me selling one in good shape running with starter and carb that came off either a 416-8 or a c-160 and after some custom plates and stab link bushings as vibration pads tractor was operational again and the 42" SD deck that it wears got me hooked instantly on having a horse addiction. I used this tractor to cut 6 acres of land (4 separate properties) and it did it flawlessly could not get that motor to bog at all even in the heaviest grass i could get it into, in the pictures that are attached you'll find the tractor after the swap and right after a bath but other than that i haven't changed anything other than belts and fluids about a month after this project was completed I was looking to upgrade once again to the larger 500 series and i found a 520HC with only 648 hours on the clock it also had the 60" deck that was in fantastic shape stole the tractor for $800 then right before Christmas I found a 56" snow blade chains and blower with custom rear weight bracket all for $500. So to wrap this up I have the fever and I'm hoping to add a few more in the years to come gonna be cruising marketplace this spring. Looking to add to the herd.
