Similar Content
By Bill D
I have a GT1800 that I have swapped an M14 into. The original drive belt is too long for the Kohler. I tried a 7473 belt and that was too long. I'm guessing I need an 81" belt. Does anyone know for sure? I'm thinking it should be the same length as a 314H? I'm trying to avoid multiple trips to TSC with the price of gas. Yes, I do have the correct hydro pulley on the Kohler. Thanks.
By 702 timmy
looking at upgrading my c-100 10 horse to a 16 horse. Can a k-341 fit into a c-100 space? Any complications? Thanks timmy
By The_turbo_tuba
I have a wheel horse 516-h and I am looking to swap in a kohler single cylinder model like a k-341 or k321. Or a magnum series single cylinder. Does anyone have any idea what the swap will entail, what parts will carry over and what things I should look for on the kohler. Also I believe the mounting plate on the current set up can be removed to fit a kohler perfectly like they would be set up on like a 310-8. In new to wheel horse so I appreciate anyone's help! Thanks!
By wheelhorsejoe
Hi Members, I am doing an engine swap in a 1988 W/H 520H replaced Onan 20hp with a B&S 18 hp twin opposed I/C. My problem is connecting the OEM main engine harness to the B/S, the B/S has a kill wire and the alternator wire go the the regulator. My problem is I don't know what wire is what in the harness and I'm unable to find a wiring schematic does anyone know the break down of the wire harness.. Any help is appreciated.. Thanks Joe
By mikekot3
Hello
I want to buy the seat mentioned in Martin Howard's 416 adventures. I tried to contact him but he is not able to receive emails through red square.
I have a 1993 WH 416-8 tractor. He used a KM UNIPRO 123 seat from www.turfseats.com
Which seat switch do I use on the replacement seat? My used my FLUKE 88 dvom in auto ranging mode to test the original seat switch. With the
seat switch disconnected I get a ohm reading and O.L when I sit on the seat. I am thinking that tells me
that the seat is Normally OPEN. Am I correct in this? Did the KM seat switch come with a pigtail for wire it up?
If not how do I install the switch? Where did you get the seat rubber bumpers for the swing up seat base? I believe they were black or grey.
Also I installed a Briggs and Stratton Vanguard v-twin 23 hp engine swap kit from small engine warehouse.
The hour meter does not work any more after replacing the swapped in engine. I was thinking that a aftermarket hour meter/tach from esitest.com would
work. http://esitest.com/329.html
My other question is that I can only start the tractor by turning the key and also turning the light switch ON to engage
the starter motor. I am thinking one of the power wires in the white AMP engine harness connector is in the wrong pin position as I had to
replace the connector.
Please advise,
Michael Kotarba
mkotarba@hotmail.com
