Chris1055 106 #1 Posted May 21, 2018 Hi I deal with napa a lot . mostly the convivence for me and the people who work there ive known along time. to make my life easier. whats the easiest way to cross ref toro bearing numbers to napa? Share this post Link to post Share on other sites
pfrederi 19,264 #2 Posted May 21, 2018 Look at the pinned bearing cross reference post at the top of this forum. That will give you the commercial bearing #s Share this post Link to post Share on other sites
WHX?? 53,326 #3 Posted May 21, 2018 If you can get the number of a seal or bearing they can most often cross it for you. There is a couple of reference sheets that @stevasaurus made up with WH to manufacturer numbers pinned at the top here in transmissions. See if those are any help when at the NAPA counter. Another trick is to measure the three dimensions of the bearing and find an online cross reference. 1 Share this post Link to post Share on other sites
953 nut 63,003 #4 Posted May 21, 2018 Best bet is to take the old bearing with you so they can match it up. 2 Share this post Link to post Share on other sites
peter lena 9,556 #5 Posted May 21, 2018 do you have a local " bearing distributor " ? they deal with industrial mechanical supply , bearings .shives.pulleys, belts , and are a great source for your problem. whenever I need a bearing, belt or seal , they have it ,at a much better price , just an idea, pete Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,845 #6 Posted May 21, 2018 Prime Line supply's Napa and I believe they use the same part numbers. See if this link works http://primelinepe.com/2016Catalog/2016/PrimeLine.html#p=92 Garry 1 Share this post Link to post Share on other sites
stevasaurus 23,515 #7 Posted May 21, 2018 In those charts in the cross over thread. You will not find a regular store chart that does a cross over from Wheel Horse bearing numbers. The charts I made above were made from the bearing measurements with matches found on the Motion Industries web site. All of those numbers are correct, and you can take those KOYO, Torrington bearing numbers and the CR/SKF seal numbers to any NAPA or other parts store and cross reference those numbers with the numbers your store has. 1 1 Share this post Link to post Share on other sites
squonk 44,860 #8 Posted May 21, 2018 Get Napa Prolink. You punch in your bearing # and if there's a Napa # for it it will pop up. See your store about it. It will check inventory at your store and distribution centers with out calling them. Share this post Link to post Share on other sites
