Countdown To Christmas!
MS GENERAL REPAIR
C-145 AUTOMATIC REPAIR VIDEO
MS GENERAL REPAIR
Good Morning Ladies & Gents;
I operate a Small Engine & Power Equipment Repair Shop From my home in Bridgeport, Ct.
Yesterday I started repairs on a 1984 +- Wheel Horse C-145 Automatic Lawn & Garden Tractor.
I decided this would be a good candidate for a repair video series on my new Youtube channel. Since the repairs on this tractor are not the usual carb cleaning & belt replacements.
Someone suggested that the Wheel Horse enthusiasts on this site might find this information useful and I hope that's the case.
Problems I'm aware of and being addressed include........... Motion Works Linkages, Hydraulic Implement Controls, Brakes & Parking Brake, Mower Blade Mounting, and whatever else I find as repairs progress.
Repair Video's have been a tremendous help to me on all types of things that I don't have a service manual for, and if this helps someone then the effort will be well worth it.
As I post this there are 4 video's in the series. More will be added in the coming days.
If you find the video's helpful please like, comment & subscribe, so I can mold the channel into a useful resource. It takes a lot of extra time to video document repairs, so it's good to know if it's worth it.
This Tractor belongs to a repair client and is Not For Sale
Good Luck With Your Repair Projects..........................Mike
Edited by MS GENERAL REPAIR
  • Like 3
  • Thanks 3
Sparky
  I’m interested to see where this one goes.
  • Haha 1
Tractor boy
:WRS: what is the name of your machine shop? I wasn’t aware of many shops around the ct/new York area.
MS GENERAL REPAIR
It's MS General Repair
I work from home.
My machining capabilities are limited. I have a small Atlas 618 Lathe, Mini Mill, 610 Kalamazoo Horizontal Band Saw, Welders, Drill Press, Torches, And a 10 x 40 lathe coming soon.
It's well equipt for the size projects I involve myself with.
That's as large as I plan on going with a lathe. Any parts I cant lift by hand can go elsewhere.
Nothing fancy, no retail location, its all about service & repair.
add info
MS GENERAL REPAIR
Here is the link to part 5
Part 5 covers machining the new bearing for motion works linkage.
It works great in the jig. Tomorrow I'll see if it works well in the Tractor.
The intro is a duplicate. The rest of the video is new.
This editing stuff is a lot tougher than mechanical work!
 https://youtu.be/PtGa6r7REsU
MS GENERAL REPAIR
Here is the link to part 6
Part 6 covers re-installation of the motion works control & linkages.
The band brake is now adjusted and adjustments need to be made to the shift linkage.
The parking brake lock still doesn't work. and judging by the total lack of wear . As I'm typing this I'm wondering if that's  a replacement part meant for a different model tractor.
It seems like there's some wear on the ratchet teeth, and no wear on the parking brake lock.
If someone serviced these when they were a newer tractor and has a little insight, your thoughts would be appreciated.
Thanks...............Mike
https://www.youtube.com/watch?v=f12hWcMYPCQ
MS GENERAL REPAIR
Should I post video's on this site as a embedded link as in post #1, so a preview picture appears,or a regular link as in the rest of my posts?
I'm not sure which is preferred on this site.
Thanks.....................Mike
MS GENERAL REPAIR
Here is Part 7 of the Wheel Horse C145 Automatic Lawn & Garden Tractor Series.
Completion of motion works repairs
Completion of parking brake repairs
demonstration of functionality.
stevasaurus
I, myself, like the embedded picture...it is also what most of us are used to.   :handgestures-thumbupright:
MS GENERAL REPAIR
Here is the link to part 8 of the 1984 Wheel Horse C145 Automatic Lawn & Garden Tractor Repair Series.
Mower Deck Inspection.
Sparky
I heard thru the grapevine that the owner of this tractor/deck combo your working on ran over a dog chain while mowing. I’m thinking that’s part if not all the reason the “nubs” on the spindles are destroyed.
  • Haha 2
Chris T
Failed to mention all of those parts. I don't think this guy knows former members here used that tractor and mower deck with no issues prior to all of this :deadhorse:
MS GENERAL REPAIR
Yes, The owner did unfortunately run over a dog lead/tether
The only damage that caused was a slight bend to the sheet metal baffle, which was easily hammered out. The sheet metal probably wouldn't have bent were it not for years of deterioration caused by normal wear & tear.
The excessive wear to these spindle shafts is clearly old. if you study the close-ups in the video you'll see that. you'll even see remnants of epoxy or something that was used to fill the voids.
I'm not trying to hide anything. If I found all this excessive wear was instead new damage caused by a foreign object, I would put the emphases on why you need to walk the property & check for foreign objects.
These Tractors & Decks were built like a Tank. I wish we had more built like this today.
My goal in producing these video's is to pass along repair information that may not be readily available elsewhere. While many viewers are accomplished mechanics, many are not. Information sharing sites like this are great. Members are always eager to share what they know on any given subject.
  • Similar Content
    • Trouty56
      By Trouty56
      Service manual #810242R3
      12 pages 1.52MB
      Dated 09/84
      Also listed as manual 492-4208
      Replaces manual #810242R1
      whlifhyd.pdf @ Toro
      A service manual for the hydraulic lift valves and cylinders.
      Included is a description of the adapters needed to make hoses and where to get them.
      1983 C-145 Automatic model 01-14KE04
      1994 416-H model 73421 Serial 4900001-4999999
      1997 416-H model 73423 Serial 7900001-7999999
    • JasonMc
      By JasonMc
      Hi guys, I purchased my firs WH - a 1976 C-120 Automatic. I have a steep hill on my property and before I go down the hill, I want to understand how my braking system works. I’m aware that this year/model didn’t include disc brakes, so is the breaking purely hydraulic Via transmission and controlled by the speed lever? Has anyone encountered issues with this? Is it safe to use on a steep hill? Any input is greatly appreciated. Thanks!
      Jason
    • Brian33
      By Brian33
      Hello,
      I am hoping someone can help my. I recently acquired a c160 for the engine for another tractor. So I did a motor swap and wanted to see what the hydro was like. I put a plow on it C-160 (which now has a 12hp engine on it). I did a quick test run and everything was good. I drained the fluid and change the filter (Napa 1410 filter and sae 30 transmission fluid as it stated to only use this fluid on the tractor.) everything was working great after the fluid change. I plowed two driveways and the sidewalks near my house... all the sudden the tractor would not go forwards or in reverse. I tried to pick the plow up and nothing... I checked my drive belt it was turning like it should. I started to push the tractor and the rear was engaged so it would not move. Of course I was 400’ from my driveway and the plow was down which made it fun. I put the tractor in forward and started to push it and the thing took off. So I hopped on and took it to the front of the garage. I put it in revers and it cut out again so I pushed it in the garage. Today I went out to check the tow valve. I took it out and cleaned the threads up put it back in and it did not change anything. According to the dipstick I have the proper amount of fluid in it. I did have a drip that I fixed on the cylinder still nothing... does anyone out there have any tips to help me out? I’ve never had a transmission like this only manual transmissions. The model of this transmission is the sundstrand 90-1140.
      Any help would be greatly appreciated.
      Brian
    • jmack
      By jmack
      I'm needing the o-ring sizes for my control valve assembly to my D-180.  Does anyone have a list of these or the McMaster Carr part numbers?
      Thanks,
      Jonathan
