hunterguy92 17 #1 Posted May 18, 2018 Well the time has come for all new tranny seals.. Is anyone making a hub puller or have a 5-lug hub sitting around? I've done some searching but to no avail.. I really don't want to use a 3-jaw puller and risk breaking a hub. What does everyone use that's readily available? Share this post Link to post Share on other sites
daveoman1966 3,762 #2 Posted May 18, 2018 got an old hub...if so, try this setup 1 2 Share this post Link to post Share on other sites
953 nut 55,837 #3 Posted May 18, 2018 If you have a bottle jack, some 3/8" all-thread and an old hub you can do this. 5 2 Share this post Link to post Share on other sites
ohiofarmer 3,276 #4 Posted May 18, 2018 If you do not have an extra hub, an automotive brake rotor can be drilled. I have some brake rotors that are close enough that just enlarging a previously factory hole or two is all it takes. Great pictures,you guys Share this post Link to post Share on other sites
953 nut 55,837 #5 Posted May 18, 2018 6 minutes ago, ohiofarmer said: an automotive brake rotor can be drilled. Great idea, the Ford/MoPar five hole 4 1/2" bolt patern is the same as the . 2 Share this post Link to post Share on other sites
Mike'sHorseBarn 3,014 #6 Posted May 18, 2018 7 hours ago, daveoman1966 said: got an old hub...if so, try this setup 1 hour ago, 953 nut said: If you have a bottle jack, some 3/8" all-thread and an old hub you can do this. I'm stealing both of your ideas! 1 1 Share this post Link to post Share on other sites
meadowfield 2,595 #7 Posted May 18, 2018 9 hours ago, Mike'sHorseBarn said: I'm stealing both of your ideas! That bottle jack looks familiar... as does that workshop... 1 Share this post Link to post Share on other sites
953 nut 55,837 #8 Posted May 18, 2018 1 hour ago, meadowfield said: That bottle jack looks familiar... as does that workshop. I was so impressed with the puller that I saved the image, but couldn't remember who to credit for the idea. I have now rectified that shortcoming! 1 Share this post Link to post Share on other sites
jeff lary 171 #9 Posted May 20, 2018 Love the homemade gear pullers both look great and very good information to have. Share this post Link to post Share on other sites
