austin joe 11 #1 Posted May 10, 2018 Corrosion and age fried the wiring harness p/n 79-3630 and Circuit board 79-2130. Any ideas on where to locate these parts? Toro was of no help. Thanks Share this post Link to post Share on other sites
oneroadkingman 53 #2 Posted May 10, 2018 I have the same problem if you look in the electrical section scroll down when you see 5:20 problems and read what they have to say you'll find your answers in there they suggest replacing the six pin plug because of the corrosion sorry I couldn't be more help but there's people on here that are better the problemand looking for files 1 Share this post Link to post Share on other sites
cleat 5,809 #3 Posted May 11, 2018 Search for " 9 Way Sealed Splash Proof Mate N Lok Electrical Wiring Multi Connector " on ebay. That is the one I bought to replace bad connectors. Here it is installed. Cleat 5 Share this post Link to post Share on other sites
oneroadkingman 53 #4 Posted May 11, 2018 Thanks cleat I'm going to look into that for mine my problem is the previous owner started cutting wires because the fuses were blown so I got to figure out what did he cut what did he try to bypass to get the thing to work cuz now I can't get it to work Share this post Link to post Share on other sites
peter lena 8,581 #5 Posted May 11, 2018 wiring issues are usually , neglect and chaffed wires. cleat did the right thing with removal and a replacement to a fail safe wire block connection. I regularly use DIELECTRIC GREASE on all my electrical connections and base ground fittings, no corrosion and positive wire connection. found many wire connections very tight or binding, causing shorts . easy to reroute/ lengthen, with a non binding fit. I found many points to correct and isolate, regularly check out your horse, prevent a break down. Pete 1 Share this post Link to post Share on other sites
lynnmor 7,302 #6 Posted May 11, 2018 Post in the WANTED section or check online auction sites for parts. 1 Share this post Link to post Share on other sites
