austin joe 11 #1 Posted May 10, 2018 Corrosion and age fried the wiring harness p/n 79-3630 and Circuit board 79-2130. Any ideas on where to locate these parts? Toro was of no help. Thanks Share this post Link to post Share on other sites
oneroadkingman 53 #2 Posted May 10, 2018 I have the same problem if you look in the electrical section scroll down when you see 5:20 problems and read what they have to say you'll find your answers in there they suggest replacing the six pin plug because of the corrosion sorry I couldn't be more help but there's people on here that are better the problemand looking for files 1 Share this post Link to post Share on other sites
cleat 6,796 #3 Posted May 11, 2018 Search for " 9 Way Sealed Splash Proof Mate N Lok Electrical Wiring Multi Connector " on ebay. That is the one I bought to replace bad connectors. Here it is installed. Cleat 5 Share this post Link to post Share on other sites
oneroadkingman 53 #4 Posted May 11, 2018 Thanks cleat I'm going to look into that for mine my problem is the previous owner started cutting wires because the fuses were blown so I got to figure out what did he cut what did he try to bypass to get the thing to work cuz now I can't get it to work Share this post Link to post Share on other sites
peter lena 8,960 #5 Posted May 11, 2018 wiring issues are usually , neglect and chaffed wires. cleat did the right thing with removal and a replacement to a fail safe wire block connection. I regularly use DIELECTRIC GREASE on all my electrical connections and base ground fittings, no corrosion and positive wire connection. found many wire connections very tight or binding, causing shorts . easy to reroute/ lengthen, with a non binding fit. I found many points to correct and isolate, regularly check out your horse, prevent a break down. Pete 1 Share this post Link to post Share on other sites
lynnmor 7,456 #6 Posted May 11, 2018 Post in the WANTED section or check online auction sites for parts. 1 Share this post Link to post Share on other sites
Rick Smith 0 #7 Posted January 26 Cleat, where did you find the 9 pin waterproof connectors? I'm interested in buying those. Thank you. Share this post Link to post Share on other sites
Wayne0 687 #8 Posted January 26 (edited) You really don't need the 9 pin connector unless you plan on swapping the motor in the future. You can use H2O proof in line fuses and H2O proof crimp connectors to eliminate it. Many here have done it. It's a very common trouble spot. Edited January 26 by Wayne0 Share this post Link to post Share on other sites
Rick Smith 0 #9 Posted January 26 Good point. I had forgotten about those. Thanks very much. Share this post Link to post Share on other sites
cleat 6,796 #10 Posted January 27 (edited) 6 hours ago, Rick Smith said: Cleat, where did you find the 9 pin waterproof connectors? I'm interested in buying those. Thank you. I used these. https://www.ebay.com/itm/130984528895?_skw=9+Way+Sealed+Splash+Proof+Mate+N+Lok+Electrical+Wiring+Multi+Connector&itmmeta=01JJJW91RACGPFES39NTZ2HRKV&hash=item1e7f494bff:g:obkAAOSwHUhZ9zsO&itmprp=enc%3AAQAJAAABIHoV3kP08IDx%2BKZ9MfhVJKkeEakmavtbUb8Hnf9kWuw%2FaqtA61Ahl%2F46NamZTYdlLs3FyAOmAncHDmGva8Q9buRyhCNrlZZOcW2XoDnbZwC9hB35go141ENIRaE9KEbaJ7Np%2BxgWaXZu073jP6RgP6DBSapL8%2BYtOoRHc9ydk%2FCErDk6wym6wmgnJvr31Oz0lAapAAQnRGb85C5RzB1NudfQMSr6nis4jY%2B7OalSe%2BtNBoVfrTv8dISWvCnY%2BpdeBDFuSmEjjPApAWU8FnvK8OZOACqTlkXuOS8qWbmeFSlxub6IhNBJS2BIMALnCdt3sm5nezI6ON1aBZxJXCA7WFW%2FWEkKr4E91iFIxzpOLeU%2BItbeimyyRFoBubDeWhomHw%3D%3D|tkp%3ABk9SR6KcpNyUZQ After installing this connector and removing the charge wire from it by running the charge current directly from the regulator to the battery cable at the starter motor through a 30A inline fuse I have never had another issue. I keep the 9 pin because I have several machines with Onan engines and if need be I can easily swap engines if ever needed. Edited January 27 by cleat 1 Share this post Link to post Share on other sites
cleat 6,796 #11 Posted January 27 If posting an actual ebay listing is not allowed then just search for 9 Way Sealed Splash Proof Mate N Lok Electrical Wiring Multi Connector Share this post Link to post Share on other sites
