TonyToro
Clutch Springs or custom spring setups info please
TonyToro
I searched the site and found some good older threads but no pictures. Pictures help me. lol
Does anyone have experience with a heavier clutch spring, if so item number please. Another thought I have been having and discovered some have done is add another spring for tension. If anyone has success with these please send pictures.
Racinbob
I use the 108035 (current #)on my 68 500 Special, 76 B/C Series, 2005 Classic and countless other tractors through the years. Basically I haven't seen a 2 piece transmission that spring won't work on just fine. Not so with the 5003/5010 3 piece transmissions. On later models any sort of dampening device gets removed and just the spring is utilized. What issues are you having where you think you need a stronger spring? :)
Edited by Racinbob
TonyToro
Last season we smoked a belt on the Raider 12. Installed a new spring from my local dealer and everything has been fine.
We are thinking of building a 14hp full out performance engine.
I am thinking to add some more spring pressure to keep the belt from slipping with the added horse power. I have read some guys installed an extra spring but I haven't seen where it is located.
I didn't keep the package from the spring I got but it could have been the same part number you suggested.
fast88pu
Stock belts, stock spring and stock pulleys and so far 0 belt slip. Even with the V twin pulling in 3H. It's rated at 22hp ;).
ebinmaine
I put an extra spring INSIDE the factory spring on my B80 because the one on it was a bit weak and I changed to a 2 inch engine pulley to slow the tractor down. I found with the smaller pulley I needed more tension.
It is just an extra from the parts box.
Just bring the existing one to a good parts store and match it up. Mine had one curled end and I bent the straight end where I needed.
RCPW sells the above spring for under $10 including freight. Least expensive I've found. It's a Toro brand.
fast88pu
Smaller pulley may not have enough belt surface area causing slipping. Possibly try stock front pulley and larger back pulley.
ebinmaine
Kyle, I think you're absolutely correct about that.
I've got it pretty much solved for now I think.
The reason for the pulley swap was too slow down reverse gear. I put on the smallest front pulley I could find and bent the tabs in on the end of the belt guard to support the belt better.
I tried to find a larger rear pulley but had very limited luck without having to spend a lot of money.
I now have an 8-speed sitting in the shed waiting to be installed in that tractor. That will certainly give me the low range I'm looking for... but it's going to be a few months before I get to it I think.
