RJC1965 160 #1 Posted May 4, 2018 What size belt do I need for the 36 inch tiller that will be mounted on a 520H Share this post Link to post Share on other sites
daveoman1966 3,745 #2 Posted May 4, 2018 (edited) s/b belt # 110265. Look up the tiller model, not the 520H tractor model. Edited May 4, 2018 by daveoman1966 Share this post Link to post Share on other sites
Rick 55 BB 24 #5 Posted May 5, 2018 Hey guys I have a belt for my tiller and I know it has to be 1/2 inch wide but is it suppose to be 138 in long or 141 inchs long ? Share this post Link to post Share on other sites
RJC1965 160 #6 Posted May 5, 2018 It seems to depend on the bracket. My tiler is a later one 95-96 so it takes the 141 inch. If you google wheel horse tiller belts you will find some good information on it. Anyone try try to use the Oregon 75-A139 belt it is a replacement for the Toro 110265 if so how did it work. It is a lot cheaper but there could be a reason why. Share this post Link to post Share on other sites
Rick 55 BB 24 #7 Posted May 13, 2018 On 5/4/2018 at 11:21 PM, RJC1965 said: It seems to depend on the bracket. My tiler is a later one 95-96 so it takes the 141 inch. If you google wheel horse tiller belts you will find some good information on it. Anyone try try to use the Oregon 75-A139 belt it is a replacement for the Toro 110265 if so how did it work. It is a lot cheaper but there could be a reason why. Thanks , been busy and rainy here so ,just now getting back to the tiller . I'm going to look them up and see what comes out Share this post Link to post Share on other sites
doc724 925 #8 Posted May 13, 2018 My comments are from memory, but if you pull the tiller manual, it will tell you. I think the belt length may be dependent upon two factors, the mid idler, and there are at lest two varieties of those, and whether you are hooking up to a single or a twin engine, That being said, I recall mine is 141 inches long and I was hooking to a K321 (14 HP). BTW, I always use Toro belts. Shop around. sometimes being cheap costs more in the end Share this post Link to post Share on other sites
RJC1965 160 #9 Posted May 17, 2018 I found out it is the 141 x 1/2 and have one on order now I found out I need the Rock shaft , cable , tube and chain. So no deer food plot tilling for awhile Share this post Link to post Share on other sites
