Bill Sherman
42 inch mower deck part numbers
Bill Sherman
I have a 1977 C-120 eight speed.  According to the number on the mower deck (05 42MS05) it is a 1986 model year.  Where can I find a parts diagram so I can get part numbers?  I need to replace the pulleys and I want to make sure I order the right ones.
daveoman1966
gwest_ca
Welcome to the forum. Click on the picture
Garry
  • Excellent 1
953 nut
:WRS:         @Bill Sherman, glad you found us, if you have other questions please post them.
One other thing,    :wwp:
Bill Sherman
Thank you very much.  I'm just getting into Wheel Horse tractors so I'm sure I'll have a lot of questions.  I have the C-120 and I just bought a C-161 automatic that hasn't even arrived yet. I'm in South Carolina and it's making it's way from Michigan.  I'll post pictures of my progress.  Thank you again.
Bill Sherman
This is my C120 when I brought it home.
Bill Sherman
This is the 1979 C161 automatic.  Still waiting on it to arrive.  I bought it from the second owner who was friends with the guy who bought it new so he knew the whole history of the tractor.  It's almost 40 years old and has been garage kept the whole time.  He even had all the manuals with it!
  • Similar Content
    • PAguy
      By PAguy
      Hello gents!
      I find myself with a question for the forum before I go down the path of ripping my deck apart in the middle of the season.
      I have a 42 inch rear discharge 78350 that seems to have developed a crack at the center spindle (photo attached). At first I thought I had unbalanced blade issue bc the deck will vibrate something fearce. Long story short took it off got everything sharp and freshly greased. Started it up and it had the vibration again that reverberates through the deck. Now it's not as as bad as before but at the wrong angle or first starting it just vibrates loudly. So looked around and found the crack at the center spindle.
      Debating if a simple weld would be sufficient for this crack or it would need more extensive repair? I don't weld myself but before I bothered the guy that farms the property thought I would ask here for thoughts if someone has had this issue since I was not seeing something in the forum.
      Appreciate your guys help and thoughts.
    • MSBiker
      By MSBiker
      Well it looks like I'm out of luck. I have been looking for blades for my Lawn Ranger and having zero luck. I have tried Wheel Horse part numbers 7908, 7909. Toro part numbers 8777, and 53322 and no one has anything like this. I was thinking about doing a cut down, but finding right hand and left hand blades seems to be the problem.
      Anyone making blades, constructing blades, got a work around, etc? My blades are usable, but that is about it.
    • Brockport Bill
      By Brockport Bill
      48" Mower Deck - Side Discharge model # 78361 -- # 312000163. This mower is listed as being manufactured at the near end of Wheel Horse production for this deck in 2012. This mower is in very good condition used only one season on small yard. Well cared for and stored indoors. The deck has double right side pulley for optional bagger attachment. Any owner who cares for this mower will have a great investment of a classic WH deck to last decades. Cash pick up Poughkeepsie, NY area. No returns. Please send p.m if interested
    • jmack
      By jmack
      What’s the correct v-belt size for a xi drive belt connecting to a 60” deck?
      Just shredded mine today.
    • BrianKoch
      By BrianKoch
      Gentlemen,
      I’m having trouble with getting my deck to raise up and lock and I think it might have to do with the deck being incorrectly set up.
      Based on the picture, does my mower deck look incorrectly positioned? That is, should the pivoting support bar be positioned above or below the wheel support pin?
      Brian
