Mattd160 73 #1 Posted April 26, 2018 (edited) Could anyone tell me what fluid goes in the hydrastatic rear end and what filter I need and also what fluid goes in the 3 point Pto tiller gear box. Thank u Edited April 26, 2018 by Mattd160 Share this post Link to post Share on other sites
953 nut 55,836 #2 Posted April 26, 2018 You will have to take a look at your transaxle dip stick to be sure, most will have an amber colored fluid, that is 10 W 30 motor oil. Some may have Dextron ATF which is a red/pink color. do not mix them, replace it with the same type fluid. The filter is a NAPA 1410 hydraulic fluid filter. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,101 #3 Posted April 26, 2018 Tiller uses 90 to 140 weight GL5 gear lube according to the manual. Click on the picture Garry 1 Share this post Link to post Share on other sites
