bo dawg 516 #1 Posted April 25, 2018 My 520 was set up with the 5' deck with the better mule that is spring loaded. I am putting the 4' deck on and the mower drive belt that's on it is too big. So... will the standard 103" length belt that is for driving the 4' deck be correct? Or since the mule is a bit different than standard will I need different size? Thanks Bo Share this post Link to post Share on other sites
Evil Archer 300 76 #2 Posted April 25, 2018 Deck Belt Toro # 1594 1/2 X 107 Mule Belt # 94-2501 1/2 X 103 1 Share this post Link to post Share on other sites
lynnmor 7,302 #3 Posted April 25, 2018 Likely need a different length, you will need to engineer that as you go. Since the geometry is different where the mule pulleys and the deck pulley are located, you might run into clearance issues as well. Share this post Link to post Share on other sites
