Bakes168
Commando 800 clutch disc
Bakes168
I need to replace the clutch disc/friction material on a Commando 800. I measured the old one and it was 6" OD and about 1/8" thick. Wouldn't this one for a PTO friction disc work? I could just drill holes for the rivets or JB weld the thing onto my existing clutch plate. Beats paying $80 for a new plate and disc.
https://www.agrisupply.com/pto-shaft-friction-disc/p/73635/
Ed Kennell
It should work.   In fact, IMO,  the disc with the center removed should work better than a solid disc.    By removing the center, the pressure will be increased on the larger diameter ring where the torque is actually transferred.
Bakes168
Thanks Ed, much appreciated!
953 nut
:WRS:          AgriSupply has been my go-to place for years and They have never let me down.
