Stealth126 54 #1 Posted April 24, 2018 (edited) Does anyone know what snow thrower will fit my 1067? Also, what brackets or modifiers will I need? The only implement I want is a snow thrower and there are a handful for sale in my area, but I'm new to Wheel Horse and am very confused what will work and what won't. None of the units I've seen for sale have model or serial information on them and I'm left to tell from grainy pictures if it will work for me. Don't want to drive 50 miles to buy something that won't work. I have an attachment list, so I know what part number will work, but how do I translate that to the real world? Edited April 24, 2018 by Stealth126 Share this post Link to post Share on other sites
Stealth126 54 #2 Posted April 24, 2018 Pictures would help me if anyone has any. I can't even picture where something like that would attach to the front of this tractor. Share this post Link to post Share on other sites
littleredrider 409 #3 Posted April 24, 2018 Almost any snowblower will mount up front. Instead of the attach-a-matic it uses a bolt that goes thru the frame. The pulleys are lil different, but can’t remember just what is different. Post some pics of some, should be able to figure out what will work. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,243 #4 Posted April 24, 2018 Here is the ST-376 (37" introduced in 1966) listed for the 1067. Click on the picture. Here is a list of snowthrowers in the order they were produced. DNA 1977 model 76-42ST01 replaces 1966-67 model ST-376, 1968 model 6-1211, 1969 model 6-6211 plus 6-9111, 1970-72 model 6-6212 plus 6-9112, 1973-74 model 6-6212 plus 6-9113, 1974 model 6-6213, 1975 model 6-6214, 1976 model 6-6215, 1976 model 66-42ST01 1977 model 76-42ST01 replaced by 1978 model 86-42ST01, 1979 model 96-42ST01, 1980 model 06-42ST01, 1981-82 model 06-42ST02, 1983 model 06-42ST03, 1984-87 model 06-42ST04, 1987-89 model 06-42ST05, 1990 model 06-42ST06, 1991-93 model 06-42ST07, 1993-2001 model 79360, 2002-07 model 79362 Where you see "plus" they came in 2 packages. The basic snowthrower plus a kit to make it fit the different models. The addition of the wings on each end of the housing increased the width from 37" to 42" and eventually became standard equipment. The tractors went to a front quick hitch in 1973 which changed the design but this hitch can also be added to the older models. The pto clutch also changed but not sure when. Front hitch. Click on the picture This can easily be made up with parts salvaged from a 1973 or later long frame tractor. Garry Share this post Link to post Share on other sites
Stealth126 54 #5 Posted April 25, 2018 https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F232743070392 This looks like a match based on the pictures, but what about the pulleys to hook up the belt? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,243 #6 Posted April 25, 2018 Can't answer you on the belt. The zinc plated pin at the rear looks to be 5/8" diameter. The original was a 3/8" bolt that went through 2 bushings in the large holes near the front of the tractor frame. Should still work with the appropriate sized bushings in the frame. If the pin is 5/8" it was likely adapted to fit the later front quick hitch. Question is did the bars the pin pass through get shortened to accommodate the quick hitch which is about 3" ahead of the holes in the tractor frame? Garry Share this post Link to post Share on other sites
Stealth126 54 #7 Posted April 25, 2018 Okay. Thank you. You guys have helped me with 3 or 4 different things already and I've only owned a Wheel Horse for 2 months. I really appreciate all the help and advice. Share this post Link to post Share on other sites
Stealth126 54 #8 Posted May 9, 2018 Got the snowblower. 37 inch. Has all the hookups and everything. Checked out the manual and read some old posts and have everything together except for I need a belt and the bushings for the frame. If anybody knows where to get the exact bushing I would appreciate it. All I could find at the local TSC were some spacers without the flange on the edge to stop it from sliding. I may have to take it to my grandpa's house and tack some washers on the outsides for flanges if I can't find anything else. Share this post Link to post Share on other sites
Stealth126 54 #9 Posted November 19, 2018 I don't see any grease zerks on any of the spindles or moving parts. Any suggestions on the best way to grease this thing? Share this post Link to post Share on other sites
rjg854 11,879 #10 Posted November 20, 2018 Maybe a needle attachment for a grease gun, kinda resembles air chuck for a basket ball etc 1 1 Share this post Link to post Share on other sites
