Countdown To Christmas!
Sandrion
Raider 10 6-speed
Sandrion
Needing to know the diameter of the transmission pulley. I work at an industrial supply house so getting the correct thing is easy if I know the diameter. I think someone replaced mine at some point, as it was for an A-belt and not a b-belt.
Thanks!
gwest_ca
The original 7492 pulley was replaced by 106165.
6-1/2" OD with 5/8" bore.
Garry
Sandrion
Thanks! I pulled one off the shelf, and grabbed a belt too. B79K (Kevlar). Hopefully this will solve the slipping belt issue.
KC9KAS
@Sandrion :text-welcomeconfetti: to :rs:
Digger 66
                    :text-yeahthat:
953 nut
:WRS:         Always good to have an industrial supply man around, we sometimes need a bit of guidance on hardware items.
Sandrion
Thanks! Lots of good information here from what I saw when I browsed a couple threads. I wound up with this tractor after I fixed it for a guy and he never came to pick it up. I can't, in good conscience, sell it, so I just use it around the yard...
