Sandrion 1 #1 Posted April 23, 2018 Needing to know the diameter of the transmission pulley. I work at an industrial supply house so getting the correct thing is easy if I know the diameter. I think someone replaced mine at some point, as it was for an A-belt and not a b-belt. Thanks! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,102 #2 Posted April 23, 2018 The original 7492 pulley was replaced by 106165. 6-1/2" OD with 5/8" bore. Garry 1 Share this post Link to post Share on other sites
Sandrion 1 #3 Posted April 23, 2018 Thanks! I pulled one off the shelf, and grabbed a belt too. B79K (Kevlar). Hopefully this will solve the slipping belt issue. 1 Share this post Link to post Share on other sites
953 nut 55,838 #6 Posted April 23, 2018 Always good to have an industrial supply man around, we sometimes need a bit of guidance on hardware items. Share this post Link to post Share on other sites
Sandrion 1 #7 Posted April 24, 2018 15 hours ago, 953 nut said: Always good to have an industrial supply man around, we sometimes need a bit of guidance on hardware items. Thanks! Lots of good information here from what I saw when I browsed a couple threads. I wound up with this tractor after I fixed it for a guy and he never came to pick it up. I can't, in good conscience, sell it, so I just use it around the yard... Share this post Link to post Share on other sites
