DANIEL/ALEASHA
Belt size Raider 10 1968
DANIEL/ALEASHA
I have a 1968 Raider 10 I need the belt size if anyone knows it
953 nut
5L-820 or B-80, both are the same size. Kevlar belts from Tractor supply are good.
DANIEL/ALEASHA
Can you get that a John Deere dealership
953 nut
I suppose you could, but the JD belt will be three times the money for the same belt.
  • Excellent 1
DANIEL/ALEASHA
I just thought it might be better quality
ericj
then go to a toro wheel horse dealer ship ....
eric j
DANIEL/ALEASHA
eric j
Do you that know the exact size of the belt
gwest_ca
Transmission drive belt 78-7100 replaced by 7473 - HB x 81.9" or 5/8" x 81.9"
Garry
DANIEL/ALEASHA
Thank you
  • Similar Content
    • jmack
      By jmack
      What’s the correct v-belt size for a xi drive belt connecting to a 60” deck?
      Just shredded mine today.
    • Xearl
      By Xearl
      I am trying to find out what the belt length is on a 48 inch deck for a 523DXI  part no. 95-3878 . Dealer wants over $70.  I want to find it at a reasonable price.
    • Yankee64
      By Yankee64
      Hello,
      I have a C-160 with 16HP Kohler that had a 42" deck on it. That deck needs some work so I switched it to my 5-0721 36" deck that I put a new deck belt and new blades on, but can't get it hooked up. I can't find the transfer belt size for this combo, I think that's what it's called, the belt to the PTO.
      I don't know what I hit, but new kids across the ally have been throwing rocks in my yard at a ground hog (all over, they have rock pile from the garden) and whatever it was, it jammed on the spindle of the 42" deck and ripped the deck where the spindle mounts. I'm going to fix it up nice while it's not in use.  Wouldn't you know, I started in the back yard and the front is starting to look bad. I've been fiddling for a few days and bought a couple of  belts but haven't gotten it right. If anyone knows the belt size for a C-160 with a 5-0721 36" deck, I'd sure appreciate your assistance.
    • TIMOTHY McCLELLAN
      By TIMOTHY McCLELLAN
      I have a Toro LX 425 W/ 44" DECK .I NEED TO KNOW WHAT THE CROSS SECTION AND LENGHT OF THE DECK BELT IS ?
    • Road-Track
      By Road-Track
      I blew a drive belt on my 1983 C-145 hydro and the belt measured 82". I looked up the correct belt and have seen many different sizes called out.
      Is 5/8" x 81" correct?
      Is 5/8" x 81.5" correct?
      or
      Is 5/8" x 82" correct?
      I also saw 98" using the same wheelhorse number????
      Any help would be appreciated,
      Thanks!
