Similar Content
By SethL1984
312-8 - Runs, new carb, ignition doesn't work. Was bought for parts, ended up being mower. Rear Attach-a-matic bracket
417-8 - Runs well, electric lift, ignition may need cleaned (or started solenoid going). Rear Attach-a-matic bracket
(1) 42" RD with mule drive. Cuts well!
(1) 48" SD with mule drive.
(1) 37" SD.
(1) 48" snow plow. 5 way blade position I believe.
Several other parts/WH odds/ends. One tractor does include the weights and chains.
Parents are moving and, unfortunately, need to thin the herd!
By JoeA
Hi First post looking for a cutting deck for an early 90's 312-8
Serial number 3112K801 11877
How big of a deck can I use ?
The original deck was a side discharge ? (42 I think )
In addition to the deck I need the assembly for the pulley assembly for the front of the tractor.
Does anyone have a picture they can post of the correct deck ?
Are these parts available new ?
Thank You for your help
Joe
Denver NC
By Bexter207
So I was using my tractor 312 WH and it just all of a sudden died out. I first thought it ran out of fuel going to check that fuel was fine. So I made sure the line was clear and that fuel was able to get to the filter. I checked the spark plug change that out and check the oil which also looks fine. It acts like it wants to start but it won't stay running. When I check the fuses one of them was destroyed and actually melted into the fuse block. This is what it looked like below. I got a new fuse and a different fuse holder just to try to see if. Still nothing. I know it has to be something that was before that fuse that either overloaded it or that that fuse was messed up in that fuse holder somehow and it kept grounding out. when I got the tractor they told me it had a new battery in it but it was dying every now and then on me and I thought that was kind of weird so I assumed there was a loose ground somewhere. I don't know if it was in that fuse or not but it kind of makes sense due to the way that the fuse looks.
I thought I'd try here first to see what any of you had for me to try. I mean I'm not scared of Chase and wires and try and things out I just thought of someone knew of something that I could check write-off and I would try. The wire color going to that fuse was purple or Violet which ever. Anyway any help is appreciated.
By Bill D
Hi,
I have a cracked seat support on my tractor. Does anyone have pictures of how they have repaired or beefed up this area? I did see a thread regarding repairs but I am trying to figure out how to beef up this area without causing problems for myself when reinstalling the belt gard and other covers. Thanks.
Bill
By Bexter207
So I have a 312 Wheel Horse. I have the Snow Blower attached and it was working great. I was using it last night when all of a sudden I heard a bang up near the the blower. I quickly disengaged the PTO lifter the blower and backed up to see if I had hit something. After inspecting i found that i did not hit anything. So I started clearing out any snow I realized nothing was stuck and the shear pins were still good. The augers had the normal amount of play. So I fired it back up and tried to engage the pto again it kind of bogged down and stalled out the engine almost. So I drove it to where i had better light. I could not see anything wrong still so I decided to try to engage it one more time to see if I could see anything. Well it started throwing so I decided to test it out and it worked fine. Then as I was going along it just stopped throwing again. So I don't know what it is. I plan on taking a look at the gearbox when I get home to make sure that's all set. Just thought I would check to see if any of you have suggestions of what I could check.
