Jamie Darian Brown 9 #1 Posted April 13, 2018 Hi all, A couple years back I put a fairmont railcar engine on a wheel horse C 141 frame to make a ride for hit miss engine shows. It's an eight speed hi lo So, I got another fairmont engine and am gonna make another ride. So I found a Raider 12 carcass rolling frame stripped down and parted out with an 8 speed trans. As I look online I see that these had a ten pinion no slip set up that people say are weaker? Should I proceed with frame I have? Or do I need to find a stronger trans? The set up is basically a ride for shows that has a double seat for two people heres a link to the first one I built so you can get an idea of what I am building 2 2 Share this post Link to post Share on other sites
wallfish 17,082 #2 Posted April 13, 2018 Don't think you'll have a problem with that trans for what you're doing. Trans is strong enough but not recommended for maybe setting up as a puller where it's going to be worked HARD. 3 Share this post Link to post Share on other sites
WHX?? 49,176 #3 Posted April 13, 2018 (edited) That would be a 5060 transmission and although you really won't the need the limited slip feature I would see no reason not to use it. They were a very strong unit with 1 1/8 axles. My biggest concern would be what does it look like internally. If you are skilled enough to build that you are skilled enough to split it for and inspection and cleaning. Perhaps replace the outboard axle bearings, seals if need be & check the 1533's. check the differential side plates as some were made of aluminum and prone to cracking if some one else was in there and over torqued them. Bearings and seals can be found here http://www.wheelhorsepartsandmore.com/index.html The other thing you may want to do in your build is inspect & reinforce the F plate area, where the frame attached to the tranny. Been know to be a weak area and you will find many ways to beef it up here. Good luck and we would appreciate some of your build! Edited April 13, 2018 by WHX16 4 Share this post Link to post Share on other sites
Jamie Darian Brown 9 #4 Posted April 16, 2018 Okie Dokie. Thanks guys. Good news. Sounds like its strong enough and will work. I will give it a good inspection and cleaning. I will get to working on it in next couple months and show yall pics of progress. 1 1 Share this post Link to post Share on other sites
Jamie Darian Brown 9 #5 Posted April 16, 2018 One more question... I was thinking of making this one a three seater. See vid of one above. Can the axles handle that much weight? With the heavy engine in front, the front end is plenty heavy enough.. just concerned about axles.... Share this post Link to post Share on other sites
