RJC1965
Kwik-way loader fluid
RJC1965
20 hours ago, roadapples said:
The speed of the loader seems to be normal... What did you do without it....
Thank you if I did not have the loader on I would have been in trouble my JD 44in Snowblower on my LA125 could not move that heavy snow even with chains on. The tractor was just to light.
RJC1965
What weight/  viscosity of  hydraulic fluid should I use there seems to be a couple different weights keep in mind I live in Wisconsin so typically doesn’t get real hot here but dose get very cold.
I checked the manual and only said hydro fluid or brake fluid
