moe1965 744 #1 Posted April 10, 2018 I'm changing the oil in my sunstrand trans. And it's taking for ever to get the oil in. I'm filling it through the dip stick tube and it keeps burping air. I have changed oil in the stick transmissions through the shifter hole to speed things up. At the rate I'm going it's going to be next year by the time I get this thing filled. Also any idea on how many quarts it would take? Thanks. Share this post Link to post Share on other sites
incabman 16 #2 Posted April 10, 2018 Take a short length of 1/8 tubing and insert down your funnel while filling and it will allow air to escape while adding fluid. Don't know how much it takes though. I'm sure someone else will let you know. Share this post Link to post Share on other sites
pfrederi 17,886 #3 Posted April 10, 2018 4-5 qts depends on how well it was drained and if you have hydro lift. Share this post Link to post Share on other sites
moe1965 744 #4 Posted April 10, 2018 I wonder if I didn't put the filter on until it was close to being topped off would let the air out?? 1 Share this post Link to post Share on other sites
953 nut 55,836 #5 Posted April 10, 2018 I have found that putting a piece of tie wire alongside the funnel will leave enough air gap to allow the transmission fluid to go down. Four quarts should get the job done. Share this post Link to post Share on other sites
moe1965 744 #6 Posted April 10, 2018 Leaving the filter off got me to the 3 qt. Mark in no time then it started to run out. I put the filter on at that point and then adding a half q t. And let the filter absorb and check in the morning. More than likely it will be a 4 q t . Fill like was posted. Thanks for all the help. Warm tempatures on the way here in the north east. Time to role the lawn. 1 Share this post Link to post Share on other sites
