bmsgaffer
Big Tires on 854
bmsgaffer
Hey everyone! Been just lurking for a few months as life got busy (and cold!). I am looking to make a "spring machine" out of one of my 854's. My yard (as most everyones) turns to a swamp this time of year, and I am looking to make a tractor that will just float on top. My 522xi, which has big tires, definately does NOT float coming in around 1100lbs without weights. I think the 854 is closer to 450lbs dry, and so if I can give it a super wide footprint it will do a lot less damage to the turf.
I know i can throw some 23x10.5-12's on the back of it with the set of rims I have, but I am wondering about the fronts. Has anyone put larger tires on the front spindles? Probably looking like 16x7.5-8 or so (the standard ones for the bigger machines).
Will I need bigger spindles? Is that too much tire for the steering components?
I will be pulling a sweeper, roller, spreader, trailer, etc...
Thanks for the help!
stevebo
I passed this machine onto another member here but here was my 854 with big tires out back. I loved the look!
  • Like 6
bmsgaffer
@stevebo I agree. I love the look! With tires that wide it will be softer than walkin on the grass. Now if I can just figure out the fronts!
I can decide if I am going with Turfs or another set of my TerraTrac K502s that I am running on my 522xi.
stevebo
Brandon-
The rears are off a 520 with 10.50's. The fronts I love the look of the tri ribs. I have 4.80 and 3.50's on other machines. I like the look of the 3.50's
RandyLittrell
You should be able to use any of the wider 8" wheels off of later models for the front end. They use the same 3/4" spindle and should just swap over.
Randy
bmsgaffer
Randy
I had not yet measured, so I wasn't sure if the spindles were longer or not on the later models. That is helpful, thank you!
RandyLittrell
Here is a pic of my C-120 for example.
RandyLittrell
I believe they may attach in a different manner, but the hub of the wheel itself, should be the same.
The wheels from my cub cadet will even work.
Randy
AMC RULES
:dunno: Ever see this...
start about the 9:50 mark here.
bmsgaffer
I had not seen that before! (i usually avoid the mud mower videos as they are sometimes painful to watch!)
For a mud mower, he did an alright job though.... Still hurts...
Thanks!
slim67
18 x 8.50-8s are what your looking for. Thats the size golf carts run. The spindles should be fine.
Herder
Looks awesome!!!!!
