69-Raider-10
What are the challenges of swapping a K181 WITH A KOHLER Magnum 14?
69-Raider-10
Happy Easter fellow Horse Junkies! I am not happy with my Raider 10 after I swapped out the Lauson for a K181. Its not so much the difference in power between the 10hp and the 8hp, its the fact that my other 2 tractors are a Bronco 14 and a 416 8 Onan. I hop on the Raider and even though its the most mechanically sound and aesthetically pleasing tractor, it has the least cajones. I have a low hour 14hp Magnum sitting around that I was saving as a backup but I think I want to drop it in the Raider. Anyone make this type of swap before? Anything that makes it not doable or ill advisable? As always I appreciate the input and your time in answering. Happy Easter!
JoeM
I've done a couple Mag converts in C120, mid 70's machines. If using the magnum muffler, the hood may need raised 3/4" in the front to clear. Of course the ignition is different, and will need a little rewire, and a ignition switch.
Not to much else as I can remember. That mag will be worth the extra power and torque.
953 nut
As Joe said, if you change the exhaust there is no interference. The wiring change will be a new ignition switch with an "M" rather than "I"  unless your present engine had a magneto.
wallfish
You may have to make some engine mounts or use J bolts for the PTO side if the M14 didn't come from a WH tractor. WH spec'd engines have threaded holes in the bottom of the oil pan for mounting the engine to the frame.
pfrederi
You may also have and issue with how the choke operates.  i put a Mag 12 onto a C-81 and the choke lever works backward..up to run down to choke.  No big deal it is my anti-theft device
  • Haha 4
69-Raider-10
So sorry for taking this long to respond all. As always, thanks a million for taking the time to help me out! I just started a business recently and it has me going nuts. I was so relieved when I finally sat down and read your replies. I thought for sure the first thing I'd read was:
"Good luck with that! Hope you're a really good welder and fabricator! First, you'll need to raise the boonozzlers up an inch and a half, then bend a new schwizzwizzler for the jenklebumpkis. And after that you better fork over some scratch for 2 new left handed wheel hamplers. Finally, you can go buy another machine because the swap is impossible."
:lol: So imagine my relief when I read the replys. LOL
Thanks again and Ill post pics upon completion!
  • Haha 2
ebinmaine
:ROTF:
Been searchin for those for Yeeeeers....
  • Haha 5
PeacemakerJack
"Good luck with that! Hope you're a really good welder and fabricator! First, you'll need to raise the boonozzlers up an inch and a half, then bend a new schwizzwizzler for the jenklebumpkis. And after that you better fork over some scratch for 2 new left handed wheel hamplers...”
Do you have any kids? Because :text-yeahthat: reminds me of an infusion of a Theodore Geisel book with the repair of a :wh: tractor!!!
classic :text-lol: I got a good laugh!
  • Haha 2
69-Raider-10
I do! LOL! I use this type of jargon with them and also with new younger fellas I hire or work with. Im known to ask for the "Shingle Stretcher" or my "Right Handed Hammer". :lol:
  • Haha 2
ebinmaine
:ROTF:
I do the saaaame stuff !!!
:ROTF:
  • Haha 1
  • Similar Content
    • Kenneth R Cluley
      By Kenneth R Cluley
      Got my parts from Lincoln, governor gear and shaft. So, I started assembly today. Took me three tries to get that two-piece crank in, thankfully it was within spec when done so I didn't have to take it back apart to shim!  Got the crank in, lapped valves and ground to spec. I found this old aluminum fixture from a hospital bed oxygen filter mount and squared it up on belt sander that worked really well on valve stem. Progress at last, will finish up soon. Hope it runs well when done! Going to put it on my 653.
    • Kenneth R Cluley
      By Kenneth R Cluley
      Okay engine Guru's, newbie needs some help! Rebuilding older 8 horse and I am new to small engines. I have rebuilt numerous car/truck engines but never a kohler k. I have researched all available videos and really appreciate the small block tutorial by Prondzy. I am at reassembly stage, so my question is, related to timing marks. I have camshaft with centrifical advance which has a groove or line on spacer that engages pawls. does this groove line up with pointed part of casting on inner rim of gear? Also, there is a groove on opposite side of camshaft gear that I believe should align with pointed mark on casting of crankshaft. See attached pictures. Thanks for any help. Just want to be sure!
    • Jennifer
      By Jennifer
      Hello everyone!  Got a real puzzle here!  Husband has visited with some on here by phone, but he is getting really frustrated!  Can anyone help us with this tractor!  It will be mowing fine, then start dying off and on at different time frames!  Temperature out side sometimes seems to play a part but could be coincident.  So he has put more and more money in this and not fixed the issue!  A list of what he has done thus far!
      new Fuel line
      new condensor
      new points
      new carb
      new plug wire
      new spark plug
      Used fuel pump
      new coil
      new switch
      new battery
      new head gasket
      soaked it with marvel mystry oil
      soaked it with sea foam
      removed fuel tank cleaned and blew out
      cleaned sediment bowl. Brand new one is on its way
      changed oil
      all 4 brand new belts
    • Wheelhorse427
      By Wheelhorse427
      The Kohler K181 on my 855 will only rev to about 2500 RPMs. When I pull the throttle cable out the whole way with the engine running, I can see the governor arm push the throttle back down. I have adjusted the governor by the manual 3 or 4 times, but it made no difference. I'm pretty sure the throttle linkage is hooked up correctly because the throttle will open the whole way when the engine isn't running. Do I need to replace my governor gear? Thanks in advance.
    • Builderchris
      By Builderchris
      I need some help. I just purchased 3 garden tractors, plus implements, from a guy on Craigslist and I'm having difficulty identifying one of them. It looks to me like it's a C100, but honestly for all I know it could be a Raider10 or a charger10 just as easily. I'm really not sure. The tag under the dashboard reads, Model T10, Serial # 329650. When I googled Wheel Horse T10 I got nothing. Can one of you great Wheel Horse guru's help me out?
      Thanks
      Chris
