tims tractors 119 #1 Posted March 22, 2018 I have fought every bolt on my 55. Can't get the 7" pulley or right hand hub any ideas I've tried pullers with heat put about as much pressure as I thought they could take without damaging. Any thoughts. Tim Share this post Link to post Share on other sites
953 nut 54,384 #2 Posted March 22, 2018 If you clamp a piece of heavy steel to the item to be removed, ground an arc welder to the shaft it is on and burn a few rods at high amperage the current passing through the rust will cause it to heat (poor electrical conductivity). The rust will become powder and you can use some paraffin to aid the removal. 10 2 Share this post Link to post Share on other sites
ebinmaine 66,585 #3 Posted March 22, 2018 @953 nut.... Heckofanidea! My first couple thoughts were: What type of Penetrating oil are you using? How much patience have you used? or do you have? Definitely headed the right way with the heat but maybe just need more? Ok that's 3 thoughts, not a couple. 4 Share this post Link to post Share on other sites
tims tractors 119 #4 Posted March 23, 2018 I've tried every kind and a couple of. Mixed types and about a months worth of patience. Is there a good pullers I'm missing? It is the oldest 55 to date according to the # and Clay I'm determined to save it an as many original parts as I can. Thanks for any help. Tim 1 Share this post Link to post Share on other sites
ebinmaine 66,585 #5 Posted March 23, 2018 I haven't had a hub be as adamantly resistant to relocation as that yet. I like @953 nut 's idea a lot and that would not ruin the pieces. There are some fantastic self made pullers on this site. The best I've seen focus on using five points of contact instead of 3. Face plate mount through lug bolts seem better than edge mount. Any pics of yours? Not often is there one that just won't move..... we just need to find the right touch. 3 Share this post Link to post Share on other sites
