Aldon 4,826 #226 Posted May 29, 2018 (edited) The Slot hitch is sold! 551 deck is sold. RJhood is sold Steering Wheel sold D series Rims Sold Here are some photos of additional items I would bring to show if someone wants them. If you see something let me know. Too many smalls to break out. the tranny is from 551 and has the hubs. Turns but needs cleaned out at minimum. Hood is an RJ hood I believe. Rims are off front of GT14. Otherwise a lot but not all came from GT14. I can’t give part numbers or specifically indicate model other than GT14 or Other. Edited June 1, 2018 by Aldon 1 Share this post Link to post Share on other sites
WHX?? 48,853 #227 Posted May 30, 2018 PM sent on the rims Aldon. Share this post Link to post Share on other sites
Lane Ranger 10,974 #228 Posted May 30, 2018 (edited) I will be bring several items to sell at this years Big Show, 1) I will have my replacement hood gaskets ( Original Part # 2767 ) for the 1965 thru 1968 Lawn Rangers, 603/604/654 and 704 that had the Tecumseh motyor gas tank filler neck thru the hood. This gasket goes around the neck on the hood. $5 at the show. 2. I will be sellingSlide Blocks ( Original Part # 6720 )for the older Wheel Horse mower decks.. $15 a pair NLA from Toro Selling a set of two replacement nylon Slide Blocks for (Part # 6720) older Wheel Horse Mower Decks. These were used on the 36 inch decks (and maybe 42) to hold the idler slide arm down . These new slide blocks are made out of Ultra High Molecular Weight Polyethylene (UHMW) an industrial grade material for long lasting service. The older mower slide blocks do wear and a replacement is no longer available from TORO/Wheel Horse for this part. The thinner under slide is usually still good to reuse from your original mower deck parts so save for placing under the slide bar. Most of these Wheel Horse mower decks that used this part wer built in the 1970 to 1980 time period. The photos show originals and the replacements . Originals were rounded on the ends but the replacement fine. I recommend putting new bolts on when changing these. 3. I also will have two early Wheel Horse snowplow/dozer blades with frame side plates. An original RJ snowplow unpainted with all the parts for $200. A combination Suburban Plow with RJ frame, repainted and new decals, frame plates and lift frame for $150. The Original RJ SNOWPLOW HAS BEEN SOLD ! Edited June 12, 2018 by Lane Ranger 1 2 Share this post Link to post Share on other sites
Aldon 4,826 #229 Posted May 30, 2018 @Lane Ranger those Nylon spacers look awesome. I’ll chase you down for a pair at the show!!!! 1 Share this post Link to post Share on other sites
Lane Ranger 10,974 #230 Posted May 30, 2018 Aldon: Be sure to help me market them ! Share this post Link to post Share on other sites
Aldon 4,826 #231 Posted May 30, 2018 Reply. Should be a no brained for anyone who has the older decks. but certainly. I’ll spread the word. Share this post Link to post Share on other sites
stevebo-(Moderator) 8,333 #232 Posted May 31, 2018 21 minutes ago, Lane Ranger said: Aldon: Be sure to help me market them ! Ebay item for sure imo Share this post Link to post Share on other sites
RJ Hamner 1,008 #233 Posted May 31, 2018 Those look great I could use a couple of pairs 1 Share this post Link to post Share on other sites
BOB ELLISON 2,981 #234 Posted May 31, 2018 @Lane Ranger I'll take a set. Those work on my 48in deck per the parts list. I had to make the old ones work with washers as spacers. 1 Share this post Link to post Share on other sites
RJ Hamner 1,008 #235 Posted May 31, 2018 Would that rubber gasket work for a Suburban? 1 Share this post Link to post Share on other sites
Lane Ranger 10,974 #236 Posted May 31, 2018 (edited) Gaskets only work on 2 1/5 inch hood hole for gas tank neck . Suburban gas tank hole in hood is smaller. RJ ! Bob: The slide blocks wear due to rusty or worn bolts and the slide bar wearing out and moving off center. Usually the bold base nylon pieces under the slide bar are still good to reuse. If not I have cut new ones out of thin sheets of plastic like material. Important that the deck be cleaned well, rust free and painted before changing bolts, etc. Edited May 31, 2018 by Lane Ranger 1 Share this post Link to post Share on other sites
Racinbob 11,115 #237 Posted May 31, 2018 7 hours ago, RJ Hamner said: Would that rubber gasket work for a Suburban? Not original but due to hood damage I decided to enlarge the filler hole and use one on my Suburban. I love how it turned out. 2 2 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,333 #238 Posted May 31, 2018 1 minute ago, Racinbob said: Not original but due to hood damage I decided to enlarge the filler hole and use one on my Suburban. I love how it turned out. Maybe it should have been. Looks oem to me Share this post Link to post Share on other sites
Racinbob 11,115 #239 Posted May 31, 2018 It just hit me. I love the restorations back to as close to original as possible but I don't really go that route as you can see on my 400. I'd prefer the cast 61 footrests over the 60 style. If someone is looking for the 60 style and has a pair of the 61 style I'm game to swap them out. 1 1 Share this post Link to post Share on other sites
WHX?? 48,853 #240 Posted May 31, 2018 Good luck with that Bob, those cast ones seem to be getting very hard to find. How did you get your filler neck to extend out that far? Share this post Link to post Share on other sites
19richie66 17,508 #241 Posted May 31, 2018 (edited) Anyone coming that has a 16-3/8” length “D” series axle shaft laying around? Looking for one for another gt14/eaton 1100 swap. Thanks. Edited May 31, 2018 by 19richie66 Share this post Link to post Share on other sites
Racinbob 11,115 #242 Posted May 31, 2018 1 hour ago, WHX19 said: Good luck with that Bob, those cast ones seem to be getting very hard to find. How did you get your filler neck to extend out that far? You're probably right but maybe I'll get lucky. I had another issue with the filler. The tank straps aren't original and a bunch thicker lowering the filler even further. I couldn't find an extended filler so I bought a new tank off Ebay and removed the neck. Much to my amazement it fit and soldered up perfectly on top of the original neck. 4 Share this post Link to post Share on other sites
19richie66 17,508 #243 Posted May 31, 2018 @Racinbob that thing looks beautiful Bob! 1 1 Share this post Link to post Share on other sites
Racinbob 11,115 #244 Posted May 31, 2018 1 hour ago, 19richie66 said: @Racinbob that thing looks beautiful Bob! Thanks Richie. A lot of the credit goes to you and your welding skills. 1 Share this post Link to post Share on other sites
Ed Kennell 38,330 #245 Posted May 31, 2018 (edited) Spring Cleaning Dumped a few buckets and took some pics. Most of this will be going on York CL. If you see anything of interest, send a PM with an offer....I could bring it to the Show. I'll dump more buckets tomorrow. S/G belt guard in pic 5 is sold. Sleeve hitch is sold. Added a few more items. Edited June 2, 2018 by Ed Kennell 4 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,333 #246 Posted June 1, 2018 Looking for a left side RJ footboard. Share this post Link to post Share on other sites
wallfish 17,023 #247 Posted June 1, 2018 2 minutes ago, stevebo said: Looking for a left side RJ footboard. Ummm, RJs didn't have foot rests. Do you mean one of those angled shoe shaped rests? 1961 or one of those bent diamond plate rests? 1960 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,333 #248 Posted June 1, 2018 3 minutes ago, wallfish said: Ummm, RJs didn't have foot rests. Do you mean one of those angled shoe shaped rests? 1961 or one of those bent diamond plate rests? 1960 Nope. It is the cast style that is rounded and the bottom has a lip your boot sits in. Share this post Link to post Share on other sites
wallfish 17,023 #249 Posted June 1, 2018 1 minute ago, stevebo said: Nope. It is the cast style that is rounded and the bottom has a lip your boot sits in. An early straight one? You say left side so assuming you mean the angled one. Got an angled one for ya but it's stuck on the shaft which was cut off. You can have it. 1 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,333 #250 Posted June 1, 2018 1 minute ago, wallfish said: An early straight one? You say left side so assuming you mean the angled one. Got an angled one for ya but it's stuck on the shaft which was cut off. You can have it. Yes John that is great. Thanks!! Going on the RJ I am redoing. Hope to have it at the show if I can get the tranny done in time. 1 Share this post Link to post Share on other sites
