Red144runner
520 front axle swap
Red144runner
I have all the parts to do the swap. Do I need to change the steering wheel shaft as well or can I keep the 3-12 shaft and run 520 parts from the reduction forward?
cleat
You need the shaft as well.
The bottom end and gear are different.
Length will likely be a bit different as well so your steering wheel may sit up just a little higher.
  • Excellent 4
