Hawk26
516-H Mower Deck
Hawk26
I'm looking for a 42" mower deck for my 516-H. Seeking expertise from WH owners who can tell me what mower decks will fit or how I can determine what mower decks will fit the 516-H model.  I believe the 516-H was only manufactured in 1988 and then the 520 followed in 1989.
Are there strict requirements when matching a mower deck to the 516-H garden tractor?  Can someone elaborate?
Not a mechanic so layman language is appreciated.
Much thanks.
littleredrider
I would think anything from the 80s back to the mid 70s. I’m not sure how many styles of deck hardware are out there.
lynnmor
Actually just about anything from 2007 back, that has the Tach-a-Matic hitch will fit.  Your tractor is not an orphan, that is the great thing about Wheel Horse.  There should be some reference material on this site, someone will be able to pinpoint it.
Ed Kennell
Yes, any deck that uses the front mule drive except the 60" off a 520 or the XI series.      Early 70s thru early 90s decks should fit.    Vertical shaft engine decks will not fit.
The earlier pre 70 side drive decks can be made to work with some minor mounting/lift mods.
gwest_ca
Here are the decks in the order they were produced
Side discharge model 05-42MS05 produced in 1988
DNA
5-1001 replaces RL-426, 5-1421, 5-1422, 5-1423, 5-1000
5-1001 replaced by 1973-74 model 5-1010, 5-1011, 5-1012, 65-42MS01, 65-42MS02, 75-42MS01 (Blades up to this point had a 5/8" x 3/4" double-D center hole)
(The following decks used blades with a 3/4" center hole) 75-42MS02, 85-42MS01, 95-42MS00, 95-42MS01, 05-42MS01, 05-42MS02, 05-42MS03, 05-42MS04, 05-42MS05, 15-42SC01, 15-42SC02, 15-42SC03, 78345
Rear discharge model 05-42MR04 produced in 1988
DNA
75-42MR01 replaces 1976 model 65-42MR01 (Both use blades with 5/8" x 3/4" double-D center hole)
75-42MR01 replaced by 75-42MR02, 85-42MR01, 95-42MR01, 95-42MR02, 05-42MR01, 05-42MR02, 05-42MR03, 05-42MR04, 15-42RC01, 15-42RC02, 78350 (The use blades with 3/4" center hole)
Blades with the 5/8" x 3/4" double-D center hole are no longer available.
Garry
