TechnoSpark 0 #1 Posted February 28, 2018 Where should I jack the front and the back from, and it is okay to leave it on jack stands for an extended period of time? Share this post Link to post Share on other sites
Racinbob 11,232 #2 Posted February 28, 2018 I've never had an issue lifting from under the transmission and front axle. Yor may want to use a short 2x4 with a hole in the center to straddle the grease zerk on the axle but I've done it without many times. 5 Share this post Link to post Share on other sites
953 nut 55,837 #3 Posted February 28, 2018 3 hours ago, TechnoSpark said: is okay to leave it on jack stands for an extended period of time? lots of us have that sat in a barn or out in the elements for decades and have come back to life. Being up on jack stands won't harm it, but you won't be getting any seat time and that is what it's all about! 6 Share this post Link to post Share on other sites
jay bee 909 #4 Posted February 28, 2018 @TechnoSpark Share this post Link to post Share on other sites
SylvanLakeWH 25,971 #5 Posted February 28, 2018 I routinely jack up the front and back from multiple places - just don't hit a grease fitting... 1 Share this post Link to post Share on other sites
Ed Kennell 38,687 #6 Posted February 28, 2018 Please remember, if you jack up the rear with the jack centered, the tractor can unexpectedly tilt to the side and possible fall off the jack. The swiveling front axle will not keep it stable. 8 Share this post Link to post Share on other sites
KC9KAS 4,741 #7 Posted February 28, 2018 37 minutes ago, Ed Kennell said: Please remember, if you jack up the rear with the jack centered, the tractor can unexpectedly tilt to the side and possible fall off the jack. The swiveling front axle will not keep it stable. You can cut some small "wedges" from wood and drive them into either side of the front axle pivot point to safely jack the rear up with out the tractor falling off of the jack. 3 1 Share this post Link to post Share on other sites
Sarge 3,463 #9 Posted March 2, 2018 One note... When greasing the front axle, support the tractor's weight on the frame with stands - then grease it. This will allow the lubricant to flow all the way around the pivot pin. With any weight on the axle the wear points won't be lubricated properly, same thing with the spindles as well. Be careful trying to get it solidly positioned on stands, some models have an unexpected balancing point and if you remove any components such as the engine it can flip off the stands. Sarge 1 Share this post Link to post Share on other sites
WHX?? 49,177 #10 Posted March 2, 2018 Don't try to run the tractor on stands. Angles can affect the splash lube. Share this post Link to post Share on other sites
