By
Sirtowsalot
Howdy y'all!
I'm having some trouble with my 418-A. I think it is ignition related, but I'm not completely sure. It starts and runs perfectly fine, but when I go to turn it off, it doesn't work. I can just turn the key into the 'off' position and take the key out while the tractor is still running and it will continue to run as if I hadn't turned the key off.
I'm trying to keep this tractor as original as possible, so I don't really want to buy a new ignition. Any help is appreciated. Thanks!
*EDIT*
Wheel Horse 418-A
Kohler Engine
18 HP
Model No. M18QS
Spec. No. 24510
Serial No. 1619706606
