JoeM 7,874 #1 Posted February 25, 2018 Brought home this 516 last year with a locked Eaton 700. Changed out the 700 with an 1100 and decided to cut a hole in the hood. I always been partial to those Mopars with the shaker hoods. Though it would be cool on a WH. the machine need a little more work, next in line to finish. 14 1 Share this post Link to post Share on other sites
Sarge 3,464 #2 Posted February 25, 2018 Now that is something completely different - and cool I must say as an old Mopar guy...nice job. Going to convert to a vacuum-actuated open air element ? Sarge 1 Share this post Link to post Share on other sites
squonk 41,643 #3 Posted February 25, 2018 Just need to raise the air cleaner a little bit so you can see the shake! Share this post Link to post Share on other sites
lynnmor 7,379 #4 Posted February 25, 2018 3 hours ago, squonk said: Just need to raise the air cleaner a little bit so you can see the shake! Use rubber to raise it, so it has a significant shake. Then we need a video. 2 Share this post Link to post Share on other sites
ebinmaine 68,873 #5 Posted February 25, 2018 4 hours ago, squonk said: Just need to raise the air cleaner a little bit so you can see the shake! 56 minutes ago, lynnmor said: Then we need a video Share this post Link to post Share on other sites
JoeM 7,874 #6 Posted February 25, 2018 I think I used a air filter from a dodge dart to raise it to that level. I'll look a little closer and see if I can raise up more. Share this post Link to post Share on other sites
