Rugerhound
Electrical Connector (Alternator) and Tail Light Assembly Questions
Rugerhound
Greetings!
I have a non-Wheel Horse tractor (Craftsman 14 HP Briggs OVH) , but the part appears to be common to the Briggs & Stratton Engine rather than a Craftsman part.  (See the photo -  The connector and pins I need are circled in blue)
I also have a 1977 Wheel Horse A-100 that needs a tail light lens & bulb.  (A complete tail light assy would be fine!)    Anyone got any idea what the Peterson part number is for the tail light for the model I have?
Thanks!!
Regards,  Pete
953 nut
The connector is probably a common B&S part that could be found at any mower repair shop.
Tractor supply sells a truck clearance light that is nearly identical to your tail light for about $ 5.00.
Rugerhound
Thanks for the tip on the clearance light!  Never gave them a thought..
Best regards,  Pete
gwest_ca
Have you looked at the B&S parts list for your motor? They may be shown on them.
A few listed in this manual
Garry
Rugerhound
Garry,
Unfortunately I can find info on the yellow connector, but not the white one that is common to the 3/5 Amp dual element stator.   Looks like a Molex connector of some sort, and I can buy the harness with the one end on it.  But finding the complete connector & pins has been (so far) elusive!!
Thanks for that download however!  It's got good info in it.
Regards,  Pete
cleat
Your local small engine shop likely has these kicking around.
Even a used one from an old machine that he may have kicking around back maybe ?
  • Similar Content
    • Rugerhound
      By Rugerhound
      Greetings everyone!
      I'm a new member to this forum and a new Wheel Horse A-100 owner.  I'd been looking for an inexpensive fixer-upper riding lawnmower to make my yardwork a little easier for an aging fellow like myself.   Snagged this A-100 for $250 that's in really decent shape for the most part.  The mower deck has some problems however, but the actual tractor is in great shape.  Doesn't look as though it was used much, and still has all the original tags on the Briggs  & Stratton stickers on the housings.  Engine sounds fine but the needle isn't shutting the fuel off properly, so it runs rough until it's revved up a bit.   The pedals have scarcely any paint worn from them.   Quite remarkable for a '77!
      So I have one of the blade shafts bound up, another that doesn't feel all that nifty.  I don't know if those bearings are sealed, or whether anyone might be able to clean 'em up and repack them for continued use.  Pulleys are in rough shape but I may be able to salvage them.    Any info on the bearings in the mower deck would be very helpful!   (Including recommended grease type, etc.)
      Also it needs a key... The Ignition switch is an INDAK 103991 which appears to cross to a Toro.   New switches are available, but does anyone know if it's possible to just purchase a replacement key?
      I'm guessing it takes typical non-detergent 30W oil...  It's a '77 model Briggs & Stratton 10 HP.  (Model 251707, code 77040412)  What fluid does the gearbox take?
      Thanks!!
      Regards,  Pete (Aka Rugerhound)
    • russellmc301
      By russellmc301
      so i figured since i see all kinds of people with projects so since i'm in the process of restoring am a-100 i thought you guys it like to  the progress.
      ill get some pictures of it later today to post.
