Similar Content
By jmack
What’s the correct v-belt size for a xi drive belt connecting to a 60” deck?
Just shredded mine today.
By ryobi.warrior
The belt on my Wheel Horse 314-8 mower deck (05-37SC01) appears to be contacting the deck bracket between the spindle pulleys. I am a novice when it comes to Wheel Horse maintenance (at best), but this does not seem correct.
I recently inherited this Wheel Horse, so I do not know the maintenance history. Unfortunately, the mechanic who previously worked on it was a no-show for a scheduled maintenance visit.
Any advice on how to address this? Thanks in advance... this seems like a great forum and I'm looking forward to spending time here!
Photos (please forgive the dirt and grime, I plan to clean it up!): https://imgur.com/a/4PknZuJ
By Chuck14025
C120, 1974/75
I added braces and shims to the rear end of the frame to beef up the cracked existing 'frame to transmission bracket'. Now, the parking brake does not engage.
The shims are about 1/8" and have to stay on.
Is there a way to adjust the parking brake?
By seven
Does anyone know what size belt is required for the rear mounted tiller off of a charger 12
By JackHorse
Hi Guys, Had a random occurrence this week. Mowing along with my C85 eight speed in 1 low (grass was thick and wet), went to depress clutch and the drive belt jumped off the idler. I've had this tractor 3 years and it's been working great. The belt itself looks good except the top of it was a bit chewed up in a short section which I believe happened after it came off. I put the belt back on and continued to mow with no further issue. Any ideas as to why this would happen or adjustments I might need to make to prevent another incident? Thanks
