classiccat
1981 Wheel Horse C85
classiccat
Got a chance to move a little metal today.
But before that, get one last  look at the speed racer paint job :auto-layrubber:
The garage was 30 degrees today but the Jasco stripper still worked OK after 30min of "incubating" under plastic:
For dent removal, I grabbed my riveting hammer, bucking bar and some various air hammer bits.  The long bit worked great for punching-out those narrow channels.  The crowned body bit was good for the raised areas and general smoothing.  (I've never done body work so feel free to correct me on the tooling names, methods, etc.).
The riveting hammer is nice as it allowed me to vary the rate and gently work the areas.  With the bucking bar on the other side, I'm able to hear when the metal is flattened-out.
The big dent in the lower right corner took the most persuasion.
Doesn't look like a match-box toy anymore... Black-Hood once things warm-up a bit.
^^^ I'll fill those holes w/ JBweld + backers (my welding skills are not up-to-par for that one)
  • Like 6
  • Excellent 1
SylvanLakeWH
Love the Blackhoods!
:ph34r:
classiccat
The machine came with the badly damaged plastic rear fender / seat pan.
You may recall that I scooped-up a metal one off of fleabay for next to nothing b/c of the damage to the left rear portion (bonus: came with a safety switch which I was missing).
Starting point; the rear light was pushed-in and the side crumpled.
After some smacks with a dead blow and smoothing with the riveting hammer:
primed to minimize flash rust and highlight what areas I still need to work-over some more:
  • Like 4
  • Excellent 3
Pullstart
Great body work!  That proves that most pieces are worth saving, or at least trying!
  • Thanks 1
classiccat
I got this beautiful receiver from Lowell a few days ago.
it was so nice, that it inspired me to rip the tractor apart for the 2nd time in the span of a year. :blink:
I know you guys like pictures of paint drying SOOOO...
3 coats of Rustoleum Tractor Implement in IH Red.
  • Like 4
  • Excellent 3
  • Thanks 2
ebinmaine
Hahahahahahahaha!!!
Hey that tractor looks awesome.... And quickly done!!
  • Thanks 1
classiccat
1 hour ago, ebinmaine said:
Hahahahahahahaha!!!
I had to work quickly...the bottle of propane I was using to heat the garage was running out!  :crying-pink:
  • Haha 3
classiccat
More red flying in a near-freezing garage... and a surprise...
IMG_1204.JPG.0a5729e5ac7ef75021bfa3ea681ae28f.JPGIMG_1205.JPG.12795f35b7eccbb88500f6e47f480d0a.JPG
I now have a leaking axle seal.   Zero slop in the axle so the only thing I can think of is that the paint thinner (mineral spirits) i used to prewash everything attacked the old rubber seal.  :kbutt:
My hubs come off like butter so i'm going to try to pluck the old seals (I'll do both sides) without splitting the case.
I believe I have the 5091 Transmission (PN 103916)... therefore I believe the axle seal PN would be 100443.  Now to do some shopping hopefully from our vendors.
Edited by classiccat
  • Sad 1
Pullstart
@classiccat this post has SKF axle seal part numbers from Napa...
  • Thanks 1
ebinmaine
Nice and easy to get 'em out from the outside.
I use a fairly sharp 1/4" wide flat screwdriver that's long enough to get past the axle and tap it with a hammer, lightly.
Just put a crease in the seal and it'll compact and crush and you can work it out from there. (Patience is your friend)
Take care not to gouge the axle.
Installation is easy as well.
Lightly sand the axle surface to smooth out and remove rust and burrs, particular attention paid to the woodruff key groove.
Put a piece of scotch or electric tape over the groove to prevent cutting the seal.
Lightly oil axle.
Install seal.
Done!!!
  • Thanks 2
WVHillbilly520H
Another thing you can try (besides what Eric said above) is to drill a couple small (1/16-3/32") holes into the metal of the old seal then thread in a couple #6 or bigger sheet metal screws then a slide hammer or upolstery clip tool can help with removal.
  • Thanks 2
classiccat
Thanks for the tips guys!  Seals are on order; i'll be replacing all-4. :handgestures-thumbup:
The garage was a balmy 45 degrees today so I tried to get as much painting in as possible... with another cold streak just over the horizon.  :occasion-snowman:
More tractor incubation in our the basement "crafts room"
Finally figured out what the InStride 1350 "does".
And another personal milestone in the Red Square gauntlet... manual removal of 38 year old dry-rotted tires.  I only slammed my shin with the tire iron once.
^^^ I had to cut the sidewall on the really crusty one.
Heaven in a plastic jug:
  • Excellent 4
  • Haha 2
ebinmaine
Hahahahahahha
Well done.
Trina and I will both do outdoor exercises readily... neither one of us likes being stuck in the house (or under any other roof) unless it's while doing projects or puttering.
Good decision to replace all 4 seals.
Also double check the bonding and thickness of the brake shoe while it's off.
Trina bought us an HF manual tire changer last year.
One of the best tool investments one could make.
  • Thanks 1
classiccat
Hahahahahahha
Well done.
I'm 50% there on getting a tire changer.  Torn between the mini & manual one;  the manual changer is bigger but it looks like you get a lot more leverage.
Maybe if my wife saw how close I was to taking a tire-iron to the teeth, she'd buy me one :D.
The InStride paint rack was a freebee...I honestly hauled it home for the box tubing.  (maybe it will make a cameo when I fab the forward-weight rack)
The brake shoe is in great shape.  I recall it being the single thing (besides paint and gasoline) that the P.O. actually changed.
  • Haha 1
ebinmaine
Given the choice between the two for working on tractor I would get the larger one.
You can use it for the entire process of changing the rear tires.
I find that the most difficult part of changing the front tires is breaking the bead and you can use the larger machine for doing that even on the smaller rims.
The only real issue with one of those is to make sure that you mount it in an area of your shop where it can be screwed down permanently and strongly and not moved again.
I would not at all advise mounting it on a pallet like some people have done online.
  • Thanks 1
classiccat
I'm in the process of cleaning-up these old rims.  3 of 4 look really good.
One will needs some work filling in the pits in the bead region before prime/paint:
The rears have these lines right at the joint.  Are these lines on all stock C-series rears?  I was about to start filling with JB Weld.
IMG_1231.JPG.6cf33965cc27a135f73946c018392ae6.JPGIMG_1232.JPG.7dc23cb320167e1a4e259fd9d08eac6b.JPG
Thanks for stoppin' by!
EDIT: I see the same perforations in some 520-H wheels on the bay (8:00 position):
bds1984
I have the smaller unit mounted to a piece of two-inch tubing that can go into the receiver of my C165 or any vehicle that is used to tow a trailer,
  • Thanks 1
wildman
Ole girl wants to mark her spot
  • Haha 3
classiccat
I've got a spot in the garage already picked-out (under a rolling toolbox)!
I saw the isavetractor dude do the same thing!   My tractor currently doesn't have wheels which leaves my truck...and knowing my luck I'd slip and tattoo my tailgate.
:text-lol:    Some horses have no couth!
  • Haha 2
classiccat
JBWeld (and alot of sanding) did a pretty good job smoothing-out the pitted bead area... (other 3 rims were in excellent shape)
Primed/Painted to stem future corrosion...I'll use bead sealant for some insurance.  (and get a peek at the Wheel Color :wh:)
^^^ Rustoleum Navajo white snagged from the local Ace HW.
After application, it's brighter (in white LED lighting) than the original wheel color (from inside the rear rims) but it does darken-up as it dries.
I really like the warm contrast with the Rustoleum IH Red Tractor/Implement:
^^^ That'll work!
  • Like 3
ebinmaine
That's what Trina and I have been using on all of ours.
We've had a few rims open as well and found it to be a dead on match for some Wheelhorse paint.
Perhaps due to age. Perhaps due to other variables... There seems to be different "off-whites" used over the Wheelhorse span just as there are different red tones.
  • Thanks 1
classiccat
Prepped for surgery.
Horse proctologist (me) got tired of digging around in there...
  • Excellent 1
  • Haha 1
Jim H
Did you get the seals replaced? I've got to replace the ones in my C-85 also and wondering how easy they were to replace.
ebinmaine
They really aren't too bad to do Jim.
Use the right tools and have patience.
No worries!
classiccat
Hi Jim, I'm splitting the transmission to replace the 4 seals.  I'll likely crack it open tomorrow to verify everything before making an order to  wheelhorsepartsandmore.
  • Similar Content
    • D_Mac
      By D_Mac
      So last fall I got this Dynamark riding mower for free. Engine ran but when you stepped on the clutch/brake it wouldn't disengage. Looking at it I noticed it was a new drive belt. I figured PO got the wrong belt so I looked up what I thought would be the correct belt and ordered it. When it came I removed the belt that was on it and it looked to be the exact same size as the new one. Put new one on and same thing. That was an 82 inch belt. So I looked again and saw that a similar model had an 85 inch belt so I ordered one of those..... close but no cigar ! Now I ordered an 86 inch and are waiting for it. In the mean time I noticed water had gotten into the gas tank. The gas cap was the style with a gage but the bubble is busted off. Since the cap goes through the hood on top water leaks in. I need a new cap but having the same issues finding correct one. I don't need one with a gauge just one the screws on tight. Any help works be appreciated as I am finding multiple part numbers.
    • Kenneth R Cluley
      By Kenneth R Cluley
      Got my parts from Lincoln, governor gear and shaft. So, I started assembly today. Took me three tries to get that two-piece crank in, thankfully it was within spec when done so I didn't have to take it back apart to shim!  Got the crank in, lapped valves and ground to spec. I found this old aluminum fixture from a hospital bed oxygen filter mount and squared it up on belt sander that worked really well on valve stem. Progress at last, will finish up soon. Hope it runs well when done! Going to put it on my 653.
    • Kenneth R Cluley
      By Kenneth R Cluley
      Okay engine Guru's, newbie needs some help! Rebuilding older 8 horse and I am new to small engines. I have rebuilt numerous car/truck engines but never a kohler k. I have researched all available videos and really appreciate the small block tutorial by Prondzy. I am at reassembly stage, so my question is, related to timing marks. I have camshaft with centrifical advance which has a groove or line on spacer that engages pawls. does this groove line up with pointed part of casting on inner rim of gear? Also, there is a groove on opposite side of camshaft gear that I believe should align with pointed mark on casting of crankshaft. See attached pictures. Thanks for any help. Just want to be sure!
    • Jennifer
      By Jennifer
      Hello everyone!  Got a real puzzle here!  Husband has visited with some on here by phone, but he is getting really frustrated!  Can anyone help us with this tractor!  It will be mowing fine, then start dying off and on at different time frames!  Temperature out side sometimes seems to play a part but could be coincident.  So he has put more and more money in this and not fixed the issue!  A list of what he has done thus far!
      new Fuel line
      new condensor
      new points
      new carb
      new plug wire
      new spark plug
      Used fuel pump
      new coil
      new switch
      new battery
      new head gasket
      soaked it with marvel mystry oil
      soaked it with sea foam
      removed fuel tank cleaned and blew out
      cleaned sediment bowl. Brand new one is on its way
      changed oil
      all 4 brand new belts
    • Wheelhorse427
      By Wheelhorse427
      The Kohler K181 on my 855 will only rev to about 2500 RPMs. When I pull the throttle cable out the whole way with the engine running, I can see the governor arm push the throttle back down. I have adjusted the governor by the manual 3 or 4 times, but it made no difference. I'm pretty sure the throttle linkage is hooked up correctly because the throttle will open the whole way when the engine isn't running. Do I need to replace my governor gear? Thanks in advance.
