608KEB
Multimeter question
608KEB
Is this the correct setting to test the battery or voltage output? I tested four different batteries. The reading is saying about 17.0-17.5 on all 4 batteries.IMG_20180210_173117488.jpg.5fa5381a79173ee43602d32984d77d73.jpg
gwest_ca
Looks correct to me and starting with the dial at 200 volts is good. If the results are less than 20 volts turn to 20 and the results may be more accurate.
Garry
Howie
200 is probably ok but I would use the 20 myself.
Sarge
You'll get a better reading on the 20vdc scale - don't ask me why it works like that - shouldn't matter but on mine it's way off when set to the 200vdc notch. I finally gave up on it and the funky readings and got a Phoenix instead.
Sarge
Achto
Check the 9v battery that powers your muti-meter. Some meters will throw high readings when the meters battery is low on power.
Edited by Achto
  • Excellent 2
608KEB
Thanks guys. I'll check the battery. I replaced the multimeter battery. I tested the old 9 volt battery. It showed 11.5 volts. Do you think my tester has possibly gone bad?
Edited by 608KEB
squonk
Has the meter been in a cold shop? It will effect the electronics even on a good Fluke meter.
ebinmaine
I have a craftsmen brand that definitely does that
Good info there... thanks.
moe1965
I'm not s electrician but I think the red wire that is plugged into the meter is in the wrong spot. Move it up so its in the dc spot.  It looks like its in the spot to read ohms.  And turn knob to 20 if your checking for 12 volts dc.  The higher numbers is for checking higher voltage.  I always start with a  high number and move down  from there.  Also is your knob 180 degrees out.  In the picture it looks like it's one click off from checking continuity . Click it one turn clockwise and touch the two leads together if it beeps your meter is not pointing to 20 volts dc hope this helps
Edited by moe1965
More info
  • Like 3
Achto
Good eye @moe1965 I missed that.
pfrederi
I think he has it correct.  The upper red outlet is for 10 amp current reads
The one he is plugged into show V Volts Omega for ohms and  then micro amps
  • Like 3
608KEB
No the garage is heated. I just snowplowed with a 520H. The volt meter on tractor  is working correctly.
I've  been to read the volts correctly  in the past with the + and - plugged in where they current are in picture.
Edited by 608KEB
Cvans
This is very true. Having worked on and in industrial refrigeration systems for years it didn't take long to figure out that digital and cold don't get along at all. I still prefer a quality analog meter.
  • Similar Content
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor!
      Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      $1175 OBO   -POOS
      (248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
      NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
    • RJ Hamner
      By RJ Hamner
      Now that we are finding more uses for the 1990 520H with a KwikWay loader I am experiencing some power loss in the hydro after about a half hour to 45 minutes??????
      Ideas?
    • lodestonefarm
      By lodestonefarm
      Selling my trusty WH520H.  ~880 hours (currently used for moving snow when needed so hours may rise) very solid machine, strong and hardworking.  20HP Onan, hydro transmission and hydraulic lift.  Has Matt's foot-pedal conversion for forward/reverse.  Included in the sale is a tall-chute snow blower and 60" mowing deck.  The blower is in excellent condition and is on the tractor currently.  The mowing deck has been a workhorse over the years.  No holes but could use some TLC, probably needs new spindles at some point and could use a couple spots touched up with welder also does NOT have any pulley covers/protectors (see photo).  Tractor has been an incredible tool, very solid and dependable and I'm certainly going to miss her when she's gone.
      Recent maintenance: replaced the plugs this summer, fluids as needed (hydro has about 100 hours on fluid/filter; oil was done in the spring and has about 25 hours on it).  Battery is about 3 years old as are the tires, Terra Trac tires on the rear and turfs on the front.  The seat (with arm rests) isn't in great shape.  I've got a cover for the seat, never used.  It's never really bothered me but new seat cover is included in sale as are 4 hub caps, chains for the rear tires, and some misc spare parts (see photos).
      I've owed this machine about 8 year and put ~350 hours on her.  She's not a show piece but could be restored.  Sheet metal is generally in shape, no rust however the hood does have a couple dings in it.
      I'm only selling because I'm trying to help my son get a small lawn care business started and looking to move to a zero-turn.  The 60" deck is too large for our trailer, the mowing deck lacks pulley safety shields, and we'd like something that mows faster.  My only complaint with this machine is the top-speed (which isn't great when comparing to today's machines) otherwise she's a beast.  They don't make them like this anymore.
    • Workin_Horses
      By Workin_Horses
      Nice solid clean 60" deck for 520H Model # C560SC04       $500 OBO
    • RJ Hamner
      By RJ Hamner
      I have a new-to me 1990 520 with a KwikWay loader. Have been going thu piece by piece and checking for anything that needs attention. Found some wobble in the rear hubs (both sides) the key ways on both the axles and hubs shoe some pretty heavy wear.  Was wondering if you have used the hub repair kits that A-Z sells and any comments good or bad?
      Thanks
      Bob
