pfrederi 17,886 #1 Posted February 8, 2018 (edited) Charger 12 was plowing today when the blade dropped. The Clevis that screws onto the cylinder shaft came off. This is the second time it has happened. Now obviously the clevis doesn't unscrew itself but the cylinder shaft must rotate over time until it falls out. Any ideas how to prevent this??? it is one of the old welded cylinders.... Edited February 8, 2018 by pfrederi Share this post Link to post Share on other sites
Sarge 3,463 #2 Posted February 8, 2018 I've had to tack weld two of those - not sure why they want to work their way off but even using red Loctite and the primer didn't work. I just zapped it right on the tip of the shaft against the clevis with the welder grounded to a clean spot on the clevis - otherwise it can conduct through the cylinder which is really bad,lol. Just extend it out as far as possible and be prepared with a wet towel to cool it after a couple of seconds to stabilize. Why those want to spin off, is well beyond me....crazy. Sarge 2 Share this post Link to post Share on other sites
hard worker 1 #3 Posted February 8, 2018 could you call me at 6095772532 i would like to ask you a few questions thank you Share this post Link to post Share on other sites
953 nut 55,836 #4 Posted February 8, 2018 3 hours ago, pfrederi said: cylinder shaft must rotate over time until it falls out. While the clevis is off I would drill and tap it for a small set screw. 7 Share this post Link to post Share on other sites
R. L. Addison 299 #5 Posted February 9, 2018 Drill it for a small Spirol pin. 3/32 would do it. 2 Share this post Link to post Share on other sites
pfrederi 17,886 #6 Posted February 9, 2018 (edited) Appreciate all the suggestions. Backed her into the shop (fell apart only 75' from it) and fired up her backup an Electro 12 to finish plowing. When you use 40-50 year old equipment having a spare is good idea. Edited February 9, 2018 by pfrederi 2 Share this post Link to post Share on other sites
Sarge 3,463 #7 Posted February 9, 2018 A pin or set screw is a great idea - more than enough meat on that particular clevis for one , not sure why I didn't think of that versus welding it but the welder was right there - begging to burn something...lol. Sarge 1 Share this post Link to post Share on other sites
pfrederi 17,886 #8 Posted February 10, 2018 Decided to try the set screw method today on 1 machine. (I have 4 Charger Electros all at the same risk) Went with it as i could pull the clevis and put in a set screw with out having to remove the cylinder to drill through the shaft itself. Will move on to the oers as time permits. 1 1 Share this post Link to post Share on other sites
Sarge 3,463 #9 Posted February 10, 2018 Let us know how it works out - that would be a better solution than spot welding it which could weaken the end of the shaft and clevis itself. Sarge Share this post Link to post Share on other sites
Spareparts 84 #10 Posted February 10, 2018 Is their not enough room for a jam nut on the rod, they make some thin ones but the set screw would be better I think Share this post Link to post Share on other sites
pfrederi 17,886 #11 Posted February 10, 2018 35 minutes ago, Spareparts said: Is their not enough room for a jam nut on the rod, they make some thin ones but the set screw would be better I think The rod does not come all the way through the clevis Share this post Link to post Share on other sites
"D"- Man 827 #12 Posted February 10, 2018 +. Perhaps Spareparts was suggesting that the thin jam nut could be placed on the shaft first, then the clevis be threaded up against the jam nut. Share this post Link to post Share on other sites
pfrederi 17,886 #13 Posted February 10, 2018 5 minutes ago, "D"- Man said: +. Perhaps Spareparts was suggesting that the thin jam nut could be placed on the shaft first, then the clevis be threaded up against the jam nut. I see, didn't think of it that way. one thing there is under 3/4" of thread on the shaft...and if they have separated in the past the last couple thread are not in the best shape. Would have to be a thin jam nut to leave enough shaft to clevis contact. 1 Share this post Link to post Share on other sites
Spareparts 84 #14 Posted February 11, 2018 They make thin jam nut,s for rod ends( Heim joints) Share this post Link to post Share on other sites
pfrederi 17,886 #15 Posted March 18, 2018 Just to update this. I put in a set screw and have plowed numerous times since. No sign of any movement. 1 Share this post Link to post Share on other sites
Sarge 3,463 #16 Posted March 18, 2018 Great, nice to hear some feedback on solutions - many times threads like this never get a follow-up. The one I tack welded hasn't moved since, but taking it apart in the future might get interesting. Sarge Share this post Link to post Share on other sites
