Similar Content
By Bttatro
I have seen these 36" gear driven decks on short frame tractors and lawn rangers alike. And I happen to have one off a lawn ranger, but have a 606 I'd like to put it on. Is this possible? Or do I need some substantial modifications?
Thanks!
By Bttatro
The title pretty much sums it up. I picked up lawn ranger? carcass for $20 in hopes the deck will work on my 606. It looks like they both use the attach-o-mattic, but I could be wrong.
Any help is appreciated. Also if anyone needs parts let me know. It doesn't have an engine, fuel tank, hood, front rims, or probably other things too. (Maybe I should just list what it does have, might be shorter)
Thanks!
By cschannuth
My old 606 rat is what I use for chores and pulling in the summer and I plan to use it to push snow in the winter. With the AGs with fluid and weights it was pretty rough on the yard when I would pull the spreader and aerator making relatively quick, tight turns. Sorta silly but I came up with some 520 wheels and cheap Chinese turfs to use in the summer. I was gonna put the rear hub caps back on but I kinda like he deep dish look for now. The AGs and caps will go back on when the snow blade does.
By Team70R
Two of my 606's both have battery trays and electric start. Both with factory 606 tags. Now my question is why not just get a 656 from the dealer ship? Was it cheaper to get a 606 and upgrade the starter? Both have the proper key ignition switches as well.
By cschannuth
Since I picked up a larger 54" blade for my C-161 I was wondering if I could add the rear axle bracket to my 606 and use my old 42" snow blade on it?
